Data Model
Elements in Structural Category
: Wall Element (WALL)
Wall Element (WALL)
Structural Element
Primary Element
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Gtype
Generic type
Number
Number
Desparam
Design parameters
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Bangle
Beta angle
LMirror
True if Mirroring required
Joistart
Start joint
Joiend
End joint
Jlnstart
Joining line start
Jlnend
Joining line end
Jusline
Justification Pline
Ctystart
Start connection type
Ctyend
End connection type
Srelease
Start releases (packed)
Erelease
End releases (packed)
Grade
Steel grade
Matref
Material reference
Ispec
Insulation spec reference
Firesistance
Fire resistance
Inref
Insulation reference
Spref
Component spec reference
Antype
Analysis type
Memline
Member line for SCTNs
Orrf
Position
Position
Orientation
Orientation
Purpose
Description code word
Tmrref
Template Repeat Element Reference
RepCount
Rule Repeat Counter
Prodrf
Reference to Production Object
Bevcodes
Bevel codes for edges
Legal Owners:
Wall Element (CWALL)
Framework Element (FRMWORK)
Subframework Element (SBFRAMEWORK)
Template Element (TMPLATE)
Legal Members:
Complementary Fitting Element (COMFIXING)
Design Dataset Element (DDSE)
Justification Line Datum Element (JLDATUM)
Spine (of Gensec) Element (SPINE)
