Data Model
Elements in Structural Category
: Secondary Joint Element (SJOINT)
Structural Element
Primary Element
Description:
The SJOINT element is used to make a logical connection between two Sections in an interconnected steelwork structure. Its position is defined relative to that of a SNOD (cf. PJOINT element).
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Gtype
Generic type
Number
Number
Desparam
Design parameters
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Posline
Positioning line
Delposition
D-position in structure
Bangle
Beta angle
Cutback
Cutback
Cutplane
Cutting plane normal
Cref
Connection reference
Jline
Joining line
Grade
Steel grade
Ispec
Insulation spec reference
Firesistance
Fire resistance
Inref
Insulation reference
Spref
Component spec reference
Jfree
True if Section position dominates a connection
Matref
Material reference
Orrf
Invfarray
Array of Inventory Items
Bevcodes
Bevel codes for edges
Excess
Excess
Legal Owners:
Secondary Node Element (SNODE)
Legal Members:
Design Dataset Element (DDSE)
Template Element (TMPLATE)
