Data Model
Elements in Structural Category
: Subfitting Element (SBFITTING)
Structural Element
Primary Element
Description:
A SBFI can represent a single penetration at which a Pipe or Section passes through a hole in a Panel or Section. Multiple penetrations are represented by a group of SBFIs (one for each penetrating item) owned by a common Compound Fitting (CMFI) or Compound Panel Fitting (CMPF) element.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Gtype
Generic type
Number
Number
Desparam
Design parameters
Shop
Shop/Site flag
Built
Built/Unbuilt flag
Arrive
Arrive Ppoint
Delposition
D-position in structure
Zdirection
Additional axis direction
Bangle
Beta angle
Cref
Connection reference
Grade
Steel grade
Firesistance
Fire resistance
Ispec
Insulation spec reference
Inref
Insulation reference
Spref
Component spec reference
Orrf
Matref
Material reference
Legal Owners:
Compound fitting Element (CMFITTING)
Compound Panel fitting Element (CMPFITTING)
Legal Members:
Design Dataset Element (DDSE)
Template Element (TMPLATE)
