Data Model
Elements in Structural Category
: Primary Joint Element (PJOINT)
Structural Element
Primary Element
Description:
The PJOINT is used to make a logical connection between a Section's start or end and a Primary Node. Its position is defined relative to that of a PNOD (cf. SJOINT element). It allows you to model indirectly, physical connections between Sections.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Desparam
Design parameters
Gtype
Generic type
Number
Number
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Delposition
D-position in structure
Opdirection
Origin plane direction
Bangle
Beta angle
Cutback
Cutback
Cutplane
Cutting plane normal
Cref
Connection reference
Jline
Joining line
Grade
Steel grade
Ispec
Insulation spec reference
Firesistance
Fire resistance
Inref
Insulation reference
Spref
Component spec reference
Jfree
True if Section position dominates a connection
Matref
Material reference
Orrf
Invfarray
Array of Inventory Items
Mdsysf
Reference Array of Model and Design Elements
Bevcodes
Bevel codes for edges
Excess
Excess
Legal Owners:
Primary Node Element (PNODE)
Legal Members:
Design Dataset Element (DDSE)
Template Element (TMPLATE)
