Data Model
Elements in Structural Category
: Panel Fitting Element (PFITTING)
Structural Element
Primary Element
Description:
A PANEL FITTING can be used to represent any item which is attached to a Panel. It may be used to indicate such things as the presence of a penetrating item or an ancillary item such as an inspection cover, doorway and so on.
A PFIT is positioned relative to the origin of its owning Panel.
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Gtype
Generic type
Number
Number
Position
Position
Desparam
Design parameters
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Bangle
Beta angle
Sjustification
Surface justification for PALJs
Cref
Connection reference
Grade
Steel grade
Ispec
Insulation spec reference
Firesistance
Fire resistance
Inref
Insulation reference
Spref
Component spec reference
Cfrarray
Cofitting reference array for Pfittings
Orrf
Invfarray
Array of Inventory Items
Matref
Material reference
Tmrref
Template Repeat Element Reference
RepCount
Rule Repeat Counter
Legal Owners:
Floor Element (FLOOR)
Wall Element (GWALL)
Panel Element (PANEL)
Screed Element (SCREED)
Legal Members:
Design Dataset Element (DDSE)
Template Element (TMPLATE)
