Data Model
Elements in Stress Analysis Category
: Nodal Release Element (RELEASE)
Stress Analysis Element
Description:
The RELE element is used to define how a stressed structure may flex under the influence of applied forces or moments. Its attribute settings control both directional and rotational movement at its owning Node. The Release directions are specified relative to a locally defined axis system.
Attributes:
Name
Name of the element
Nrelease
Nodal releases
Laxes
Local axes
Dflfactors
Translational spring values
Rflfactors
Rotational spring values
Description
Description of the element
Orrf
Legal Owners:
Compound fitting Element (CMFITTING)
Fitting Element (FITTING)
Equipment Load Point Element (LOAPOINT)
Panel Vertex Element (PAVERT)
Primary Node Element (PNODE)
Secondary Node Element (SNODE)
Legal Members:
None
