Data Model
Elements in Stair Category
: Stair Tower Element (STRTWR)
Stair Element
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Area
Area
Number
Number
Matref
Material reference
Position
Position
Orientation
Orientation
StrCon
Stair Configuration
StrStd
Stair Standard
InstOptions
Installation Options
INTSEN
Installation Sense - true if clockwise
ColXSpacing
Spacing between columns in the X direction of the tower
ColYSpacing
Spacing between columns in the Y direction of the tower
FCLXSpacing
Spacing between stair flights in the X direction of the tower
FCLYSpacing
Spacing between stair flights in the Y direction of the tower
LndLevels
Landing levels from owning element
BmLevels
Beam levels from owning element
Thickn
Thickness
TWidth
Tread Width
Headroom
Headroom
HeadClearance
Head Clearance
FThickness
Stair Flight Thickness
OpHeight
Operational Height
OpWidth
Operational Width
OpLength
Operational Length
CLBaseOffset
Column base offset
ASLStandard
ASL Standard Reference
ASLSbStandard
ASL Substandard Reference
FireRating
Fire rating
Firesistance
Fire resistance
Dcrfarray
Array of Design datasets for Design Code/Criteria
LabOffset
Label offset
Legal Owners:
Framework Element (FRMWORK)
Subframework Element (SBFRAMEWORK)
Structure Element (STRUCTURE)
Stairwell Element (STRWELL)
Legal Members:
Access Point Set Element (ACCSET)
Design Dataset Element (DDSE)
Stair Flight Element (STRFLT)
Stair Landing Element (STRLNG)
Tower Steel Element (TWRSTL)
