Data Model
Elements in Accommodation Category
: Stairwell Element (STRWELL)
Accommodation Element
Primary Element
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Number
Number
Area
Area
Position
Position
Orientation
Orientation
Heidefault
Default Height value
StrCon
Stair Configuration
AreaReference
Area reference
ColSchema
Color Schema
CWidth
Clearance Width
Headroom
Headroom
HeadClearance
Head Clearance
FThickness
Stair Flight Thickness
OpHeight
Operational Height
OpWidth
Operational Width
OpLength
Operational Length
AccLevels
Access Heights for Stairwell
LndLevels
Landing levels from owning element
LevRfA
References to levels serviced by stairwell
Temperature
Temperature
MaxTemperature
Maximum Temperature
MinTemperature
Minimum Temperature
Humidity
Design Humidity
MaxHumidity
Maximum Humidity
MinHumidity
Minimum Humidity
Pressure
Pressure
MaxPressure
Maximum Pressure
MinPressure
Minimum Pressure
MaxWater
Maximum Water Level
AirChangeRate
Air Change Rate
Occupancy
Occupancy
Lighting
Lighting requirements
FireRating
Fire rating
Firesistance
Fire resistance
WaterTight
Water Tight
GasTight
Gas Tight
DClnType
Default Ceiling Type
DClnCode
Default Ceiling Code
DFlrType
Default Floor Type
DFlrCode
Default Floor Code
Dcrfarray
Array of Design datasets for Design Code/Criteria
LabOffset
Label offset
Legal Owners:
Building Block Element (BBLOCK)
Building Level Element (BLEVEL)
Open Space Element (OPENSPACE)
Room Element (ROOM)
Legal Members:
Access Point Set Element (ACCSET)
Area Definition Element (AREADEF)
Boundary Line Element (BNDLIN)
Detail Group Element (DETGRP)
Design Dataset Element (DDSE)
Inventory List Element (INVLST)
Boundary Element Set Element (SPBSET)
Stair Landing Element (STRLNG)
Stair Tower Element (STRTWR)
Stair Flight Element (STRFLT)
