Data Model
Elements in Accommodation Category
: Kickplate Element (KICKPL)
Accommodation Element
Attributes
Name
Name of the element
Description
Description of the element
Function
Function
Spref
Component spec reference
Desparam
Design parameters
Matref
Material reference
Level
Drawing level
Bangle
Beta angle
Xoffset
X-offset
Zoffset
Z-offset
LMirror
True if Mirroring required
Jusline
Justification Pline
BendCorners
Bend corners - true if fillet should be applied to the corners of kickplate
Ydirection
Preferred Y axis direction
Drnstart
Plane normal at start of SCTN/GENSEC
Drnend
Plane normal at end of SCTN/GENSEC
StaRef
Cable Start reference
SPkdistance
Proportional distance of start point along Pline
Szdistance
Start load point in section
EndRef
Cable End reference
EPkdistance
Proportional distance of end point along Pline
Ezdistance
End load point in section
AssTmpReference
Assembly Template Reference
Legal Owners:
Kickplate Set Element (HRKPSE)
Legal Members:
None
