Data Model
Introduction to Attributes
List of All Attributes
: Attribute W
Attribute W
Attribute Name
Data Type
Qualifier
Description
W
real
Position westing
WALLTH
real
Tube wall thickness
WAMA
real
Maximum water level
WANS
word(100)
Word answers
WATERT
logical
Water Tight
WATTIM
real
Water cleaning time
WBORE
real
Bore on IWELD/RWELD
WCANG
real
Weld connection angle
WCOM
string(26)
Weld comment
WDBNA
string
Working DB name
WDESP
word(100)
Design parameters as words
WDIA
string(1000)
Wind diameter modulus
WEFA
real
Weight multiplier
WEIG
real(3)
Weighting value
WELDDP
real
Welding depth
WELDMC
element
Welding Machine Reference
WESUSP
real
Weld end suspension
WHOLEC
real
Array of Whole Cells
WIANG
real
Weld inclination angle
WIDARR
real(10)
Width array
WIDT
real
Width
WIFA
real
Wind multiplier
WJPOS
pos
Implied weld position
WJUSL
word
Wall Justification Line
WLDC
integer
Weld Code
WLDN
integer
Weld number
WLDP
string(4)
Weld number prefix
WLDPOS
string(26)
Welding position
WLDREF
element
integer
Return reference from Ppoint or WELD to IWELD or RWELD element
WLEGL
real
Weld leg length
WLEN
real
Weld length
WMAX
integer
Maximum weld number in current spool drawing
WNAM
string(26)
Weld name
WNLAY
integer
Number of weld layers
WORI
ori
World orientation
WORPOS
pos
World position
WPAR
word(100)
Parameters as a word
WPRE
real
Wind pressure
WPROC
string(26)
Welding process
WRANG
real
Weld rotation angle
WSHOP
logical
Weld shop/site flag on IWELD/RWELD
WSPEC
element
Weld specification on IWELD/RWELD
WSPROC
string(26)
Welding standard process
WSSUSP
real
Weld start suspension
WTCOM
string(300)
Weld table comment
WTEREF
element
integer
Wall thickness element reference
WTHICK
real
Wall thickness
WTHREF
element
Wall thickness table reference
WTOL
string(1000)
Wall thickness tolerance / Weight tolerance
WTORCH
dir
Weld torch vector
WTPROC
string(26)
Welding test procedure
WTRANS
real(12)
Transformation matrix to world
WTSTAT
string(26)
Weld table status
WVOL
real(6)
Enclosing box volume in world coordinates
