Data Model
Introduction to Attributes
List of All Attributes
: Attribute V
Attribute V
Attribute Name
Data Type
Qualifier
Description
VALARR
element(100)
Valid Status Values
VALIDV
string(1000)
Valid value expression for VVALUE elements
VALNAM
string(50)
Local Name of a Status Value
VALNUM
integer
Numerical representation of a Status Value
VALREF
element
Status Value reference
VALRUL
string(1000)
Valid rule expression to test VALIDV attributes of VVALUE elements
VALTEX
string(120)
Textual representation of a Status Value
VANGLE
real
Angle from vertical
VCOMPD
string(50)
View Comparison Date
VCOMPS
element
View Comparison Stamp
VDISTA
real
Vertical Distance
VDPOS
pos
Dimension line/arc position
VDTINT
integer(2)
Verification date
VDTTXT
string(22)
Verification date text
VENID
string(120)
LMI Vendor ID
VERTDI
logical
VERTDI (true if Z axe is vertical )
VFLSTZ
integer
View frame line type zero is ByStyle
VFRCOL
integer
View frame colour
VFRLST
integer
View frame linestyle
VGAP
real
View gap length
VHEIGHT
real
Volume height
VIRF
logical
Virtual Flag
VISF
string(73)
Visio filename
VLAYRF
element
Visual layer reference
VLIM
real(6)
View limits
VMAR
real
ADP view margins
VMCIAR
integer(10)
VM Component Int Array
VMCRAR
real(10)
VM Component Real Array
VMDRPDMS
logical
VM Draw anno using pdms engine Y/N
VMFCFB
logical
VM Fill Colour From Border Y/N
VMFLAY
integer
VM Fillstyle Layer
VMGLAY
integer
VM Geometry Layer
VMTASP
real
VM text aspect
VMTSLA
real
VM text slant (degrees)
VMUSYS
integer
VM Fillstyle Unit System
VNREF
element
VNOTE reference - special attribute for use by ADP
VOLTAC
string(1000)
Voltage AC
VOLTDC
string(1000)
Voltage DC
VRADI
real
Cableway radius
VRAT
real(2)
View ratio
VREG
real(4)
View region
VSCA
real
Viewing scale - scales projected view
VSHAPE
integer
Volume shape
VTITL
string(120)
View title
VTYP
string
Type of design view
VVOL
real(6)
View volume
VWIDT
real
Volume width
VWLIMI
real(6)
View Limits - special attribute for use by ADP
VWREFA
element(20)
View reference array - special attribute for use by ADP
VWSTRF
element
View style reference
VXREF
element(500)
Vertex reference array
