Data Model
Introduction to Attributes
List of All Attributes
: Attribute U
Attribute U
Attribute Name
Data Type
Qualifier
Description
U
real
Position upping
UAEXSS
real
User Excess Arrive
UALL
logical
UALL
UAREA
real
Used area
UBULG
real
Used bulge factor for curve geometry
UCAT
string(120)
Category on forms
UCOD
integer
Units code
UCODB
integer
Units code bore
UCODD
integer
Units code distance
UCONN
logical
True if the UDA value should appear on the reference list form
UCURTYP
word
Used curve type
UCUTDI
dir
Upper Extension Cutting Direction
UDACPY
element
UDA copy
UDALIS
word(2000)
List of UDAs
UDASET
word(2000)
List of UDAs set
UDATLS
word(200)
List of attributes for UDET
UDETCHECK
string(120)
Report from UDET check on element
UDHLIST
word(120)
Attributes hidden on elements of this user-defined element type
UDIRECTION
dir
Up axis direction
UDMLIST
word(120)
List of allowed member types
UDNA
string(50)
User defined name
UDOLIST
word(120)
List of allowed owner types
UDPEND
word(100)
list of attributes that this attribute depends on
UDPMEM
word(500)
Possible type members for a UDET
UDPOWN
word(500)
Possible owners for a UDET
UDTABL
logical
Determines if UDA is to be indexed in a table for fast access
UEEXSS
real
User End Excess
UEXTNS
real
Upper Extension Length
UGOING
real(10)
Upper Tread Going
UHIDE
logical
Set true to hide attribute on forms
UHYPER
logical
Set true to treat attribute value as a named link to an external resource
UIWE
string(1000)
Unit insulation weight
UKEY
integer
UDA key - internal unique system identifier
ULEN
integer
Length of data or text
ULVOPT
logical
Determines if UDA valid values or range limit is optional
UMAX
real
Maximum value
UMIN
real
Minimum value
UNAM
string(12)
Name of user
UNDERL
logical
Underling flag
UNRESO
logical
attr
T/F on attributes that are unresolved references
UPDCB
string(500)
ADP update callback
UPGDDB
integer
Upgrade number for DB
UPLLEN
real
Used raw plate length
UPPING
pos
Upping part expressed as a position
UPPREF
element
References to upper exit level
UPRLEN
real
Raw profile used length
UPROMPT
string(40)
Textual prompt to display to the user
UPROTE
logical
Set true to disallow viewing the attribute in a protected database
UPSEUD
logical
Set true to calculate attribute value rather than store it in a database. User code must be provided
URADI
real
Used radius for curve geometry
UREF
element
Units reference
URISE
real(10)
Upper Tread Rise
URL
string(1024)
URL
USCCOG
pos
User derived centre of gravity position
USCLHI
element(5000)
Elements in descendant hierarchy claimed to this user
USCWCO
pos
User derived wet centre of gravity position
USCWEI
real
Derived value for user weight
USCWWE
real
Derived value for user wet weight
USEF
element
User reference
USERC
string(120)
User name of user claiming element
USERLS
element(1000)
List of USERs belonging to TEAM
USERM
string(120)
attr
User making last modification
USESS
string(120)
integer
User creating session
USNCLH
element(5000)
Elements in descendant hierarchy not claimed to this user
USRCOG
integer(500)
User centre of gravity position
USRLI
element(50)
Valid users for given user login
USRWCO
integer(500)
User wet centre of gravity position
USRWEI
integer(500)
User entered weight value
USRWWE
integer(500)
User entered wet weight value
USYSTY
word
Name of the system attribute
UTEAMS
element(500)
Teams that will see a hidden attribute
UTYP
word
Type of the value. INT, REAL, TEXT, REF, LOG, WORD, POS, DIR or ORI
UUID
string(36)
Universally unique identifier
UUIDAR
integer(4)
Universally unique identifier, stored array
UUIDREF
element(500)
word
Universally unique identifier references
UUNI
string(20)
Units of attribute values (bore/distance/text)
UVVAL
string(500)
Valid value for UDA
UWEI
string(1000)
Unit pipe weight
UWGHT
real
Used weight
UWIDTH
real
Used width
UWMTXT
string(120)
User weight Manager text
UWP
pos
Upper Working Point
