Data Model
Introduction to Attributes
List of All Attributes
: Attribute T
Attribute T
Attribute Name
Data Type
Qualifier
Description
TABANS
real(10)
Tabular answers
TAGCD
integer
Tag code
TAGCDS
integer(25)
Tag codes
TAGNMS
integer(25)
Tag numbers
TAGNUM
integer
Tag number
TANGLE
real
Tile Angle
TANGOF
real
Tangent offset
TANS
string(257)
Text answer for text styp in spec
TARF
element
Target reference
TATYPE
string(10)
Text answer type
TBID
integer
Tribon ID
TBNAME
string(25)
TbName
TBOR
real
Tail bore
TCAT
element
Trace catalogue reference
TCDD
string(250)
word
Current design property default value
TCDP
string(250)
word
Current design property value
TCOD
string
Hashed origin code
TCON
word
Tail connection type
TCORRO
real
Tail Corrosion
TCREF
element(10)
Tail connections
TCTL
real
True cut length
TDEF
string(257)
Text default for text styp in spec
TDET
element
Trace detail text reference
TDIR
dir
Tail direction
TDMF
element(2)
ISODRAFT Reference Dimension attribute
TDMT
word(2)
TDPR
real
word
Template design dataset property
TDRT
string(2000)
Trace detail RTEXT
TDST
string(2000)
Trace detail STEXT
TDTT
string(2000)
Trace detail TTEXT
TEAMLS
element(1000)
List of TEAMs to which USER belongs
TEASTA
word
Access Control team status
TEMF
element
Team reference
TEMP
real
Temperature
TEND
string
Connection at other end of TREF (HEAD or TAIL)
TEQDES
string(120)
To Equipment Description
TESTEV
logical
Result of constraint test evaluation
TESTXP
integer(500)
Logical Expression
TEXIST
logical
True if component has TUBI. Always true for offline bends.
TFDP
element
word
TGEOM
logical
True if component has TUBI geometry
TGRA
real
Pipework temperature gradient
THERMA
string(26)
Thermal category
THICKNESS
real
Thickness
THPO
pos
Point through which viewing
TIERHE
real(15)
Heights of trays measured from path
TIMEEND
integer
End time of COMMS window
TIMEINTERVAL
integer
COMMS retry time interval
TIMEOUTNUMBER
integer
COMMS max retry count
TIMER
string(120)
Frequency of DB propagation
TIMESTART
integer
Start time of COMMS window
TIMFAC
real
Pathtime time factor
TIMPET
string(15)
Time factor pre text
TIMPOT
string(15)
Time factor post text
TITL
string(1000)
Title
TLCONN
element(500)
List of elements connected to branch tail
TLIN
logical
True length indicator
TLREF
element(500)
List of attachment connected to attachment
TMAT
element
Trace material text reference
TMAV
real
Average temperature
TMDWG
string(120)
AutoCAD template name
TMMA
real
Maximum temperature
TMMI
real
Minimum temperature
TMPLTF
string(2000)
Datasheet Template filename
TMPR
element
Template reference from SPCO
TMRF
element
Template reference
TMRMASTER
element
Template Repeat Master Duplicate Element
TMROWNER
element
Template Repeat Owning Element
TMRREF
element
Template Repeat Element Reference
TMRRULE
integer(500)
Template Repeat Rule
TMRXREF
element(500)
Return reference from TMRREL element to repeat elements
TMXT
string(2000)
Trace material XTEXT
TMYT
string(2000)
Trace material YTEXT
TMZT
string(2000)
Trace material ZTEXT
TOPCUT
real
Top Stile Cut Distance
TOPOLOGY
string(120)
Branch topology
TOTALT
real
Total machine time for a nested plate
TOTLAB
real
Total label pathtime
TOTLEN
real
Total length
TOTT
real(2)
Total pathtime
TOTTI
real(2)
Total pathtime, I-bevel
TOTTX
real(2)
Total pathtime, X-bevel
TOTTY
real(2)
Total pathtime, Y-bevel
TPAR
real(30)
Trace catalogue component parameters
TPEN
integer
Text pen
TPLFRR
element(10000)
integer
Topology references - from
TPLFRT
integer(10000)
element
Topology reference types - from
TPLTOR
element(10000)
integer
Topology references - to
TPLTOT
integer(10000)
element
Topology reference types - to
TPON
integer
TO port number
TPOS
pos
Tail position
TPOSE
real
Easting of tail position
TPOSN
real
Northing of tail position
TPOSTO
real
Top post offset
TPOSU
real
Upping of tail position
TPREF
element
Tail point reference
TPRESS
real
TestPressure
TPVAL
string(1000)
Task parameter name
TQUAL
string(257)
Text qualifier in spec or sele
TQUES
string(257)
Text question in spec or sele
TRANS
real(12)
Local transformation matrix
TRAYH
real
Tray height
TRAYOW
real
Tray other width
TRAYRW
real
Tray Reduce Width
TRAYSW
real
Tray side width
TRAYW
real
Tray Width
TRCG
logical
DRAFT user defined symbol trace flag
TRCLIN
word
Trace line
TREADD
real
Tread Depth
TREADO
real
Tread Overlap
TREATP
element
Tread type
TREF
element
Tail reference
TRGENA
logical
Initial Value
TRIMCE
integer(10000)
Array of Trimmed Cells
TRIMTY
word
CTWALL TRIM TYPE
TRLEN
real
Tracing length
TRSF
element
Tag ruleset reference
TRUN
real
Truncation value (+ve) or percentage (-ve)
TRUNTX
string(80)
Truncation value (+ve) or percentage (-ve) text
TSFBR
logical
Spooling marker for leave tube
TSIZ
real
Terminator size
TSIZTX
string(80)
Terminator size text
TSLEN
real
Total suspension length
TSPE
element
Tracing spec reference
TSPR
element
Trace specification component reference
TTEX
string(120)
T Text string
TTFACE
string(128)
TrueType font face name
TTFDES
string(128)
TrueType font description
TTFENA
logical
TrueType fonts enabled flag
TTFIND
integer
TrueType font index
TTHOFF
real
Top Tube Hoop Offset
TTYP
word
Template type
TUCL
real
Tube centreline length of branch
TUFG
logical
Tubing flag
TUFL
logical
Tube flag
TULE
real
Tube length of branch
TVIS
logical
Top visibility flag
TWALLT
real
Tail wall thickness
TWIDTH
real
Tread Width
TWIST
logical
True if twisted
TWLEN
real
Total weld length
TWRF
element
Tail Working Point (Router)
TWSTAN
real
Twist angle
TXALIGN
string
Text alignment
TXAREA
real
Total Cableway X-area
TXCOLG
integer
GLabel style text colour
TXCOLO
integer
Text colour
TXCONU
integer
Text colour number
TXHINT
word
Text height interpretation mode flag
TXSPLI
logical
Text splitting flag
TXSTRF
element
Text style reference
TXSTRI
string(1000)
Text String for enhanced LineStyles
TYNU
integer
Number type
TYPE
word
Type of the element, ignoring UDET, truncated to 4 or 6 characters
TYPEA
string(10)
TYPEA
TYPEB
string(10)
TYPEB
TYPECD
integer
Type code
TYPECE
integer
Type code
TYPEDB
string(6)
DB type
TYPEXPRESSION
string(1000)
Type Expression
TYPEXTYPE
string(15)
Type expression type
TYPINC
logical
Type is inclusive
TYSEQU
integer
Type Sequence Number
