Data Model
Introduction to Attributes
List of All Attributes
: Attribute S
Attribute S
Attribute Name
Data Type
Qualifier
Description
S
real
Position southing
SAFC
integer
Safety class
SAVDIR
dir
Cached direction
SAVPOS
pos
Cached position
SBRA
element(10)
SBOLT references
SBRP
element
SBFR to RPLA reference link (Router)
SCAL
integer
DRAFT user defined symbol scale factor
SCALI
real(500)
ADP main view allowable scale list
SCALIN
logical
Drafting symbol link scaling flag
SCALPH
logical
ALPHA/NOALPHA flag
SCAREF
element(10)
Area shape reference
SCBREF
element(50)
Schematic element back reference
SCDELI
string(50)
Delimiter
SCDIGIT
integer
Digits
SCEIRE
element(60)
Enhanced instrument relationship
SCELOR
element(20)
Enhanced instrumentation loop reference array for schematic elements
SCGTYP
string(50)
Schematic nozzle gtype
SCHED
string(10)
Piping Schedule
SCHELE
element
Schematic head element
SCHEME
string
Scheme name
SCHFF
integer
Schematic file format
SCHLNK
element
Connectivity Schematic Link
SCHTYP
integer
Schematic type
SCIERTYPE
word(60)
Instrument enhanced reference type
SCIIRE
element(50)
Instrument to instrument reference
SCIIRTYPE
word(50)
Instrument to instrument reference type
SCIPRE
element(50)
Instrument process reference
SCIPRTYPE
word(50)
Instrument process reference type
SCIREF
element(10)
Instrument reference
SCIREL
element(50)
Instrument relationship
SCIRLTYPE
word(50)
Instrument relationship type
SCIRTY
word(10)
Instrument reference type
SCLORE
element(10)
Instrumentation loop reference array for schematic elements
SCOD
string(3)
Isodraft Compipe: Short code
SCOPEREF
element
Access Control scope references from ACR
SCOSEL
integer(500)
SCOSLX
integer(500)
SCPANA
string(120)
Schematic page name
SCPATY
word
Schematic page type
SCQUAN
integer
Quantity
SCRAPT
real
Total scrap of raw plate area
SCRAPU
real
Total scrap of used raw plate area
SCREF
element
Schematic element reference
SCSTYP
string(257)
Schematic stype
SCSYSD
element(500)
System reference array for schematic diagrams
SCSYSF
element(10)
System reference array for schematic elements
SCTDIR
dir
Section Direction
SCTELE
element
Schematic tail element
SDISTA
real
Vertical Distance of Start
SDTH
real(3)
Saddle thickness
SDTINT
integer(2)
Splitting date
SDTTXT
string(22)
Splitting date
SECTYP
string(120)
Gpart Secondary type
SEGE
pos
Segment end point position
SEGS
pos
Segment start point position
SENS
string
Rotational sense
SEQU
integer
Sequence Position in Member List
SESCLA
integer
Session Of Claim
SESSC
string(120)
integer
Comment for specified session
SESSCA
integer(2000)
List of pairs of DB number, last session number for all referenced DBs
SESSCH
integer(2000)
As for SESSCA, but searches all descendants for referenced DBs
SESSD
string(120)
integer
Date of specified Session
SESSM
integer
attr
Session Of Last Modification
SESSNO
integer
Current opened Session
SESSU
string(120)
integer
User creating specified session
SETDATE
string(120)
Set Date
SEXPND
element(10000)
All descendent elements in secondary hierarchy
SFCODE
integer
Stiffener Code
SFLIMI
word
Spooling limits
SFOR
real(3)
Start force vector component
SFREF
element
Return reference from piping component or leave tube to spool or field element
SHAP
string(1000)
Shape modulus
SHDPOS
real(2)
Dimension line/arc sheet position
SHFALG
real
Shrinkage factor along main direction
SHFPRP
real
Shrinkage factor perpendicular to main direction
SHFSEA
real
Shrinkage factor for seams perp. to main direction
SHIPNO
string(80)
Ship number
SHIPX
string(20)
Ship X position
SHIPY
string(20)
Ship Y position
SHIPZ
string(20)
Ship Z position
SHOC
real(3)
Shock load vector
SHOP
logical
Shop/Site flag
SHOPRI
logical
Shop Primer
SHOWKP
logical
Show kickplate in default representation
SHPSYM
string(40)
Shape symbol text
SHPUV
pos
Point defining shrinkage
SHRF
element
Reference to associated sheet or library
SHTNUM
integer
Sheet Number
SHTOT
integer
Total Sheets
SHVUV
dir
Vector defining shrinkage
SHXYPS
real(2)
2D Sheet Position
SIF
real(3)
Stress intensification factor
SIGF
integer
Significant figures
SIGREF
element
Significant point reference
SITEM
element
Reference from secondary hierarchy
SIZE
real(2)
Sheet/region size
SIZEDB
integer
Size of DB
SJUS
word
Surface justification for PALJs
SKEY
string(4)
Symbol key
SKEYSCALE
integer
Universal SKEY scale factor
SLENGTH
real
Side length
SLHNAP
element(500)
Sorted list of HNODE after POINTR
SLHNBP
element(500)
Sorted list of HNODE before POINTR
SLOPEF
logical
SLOPEF (True if its a sloping wall else step change)
SLOREF
element
Pipe slope reference
SLRAP
element(500)
Sorted list of RATTA after POINTR
SLRBP
element(500)
Sorted list of RATTA before POINTR
SMAX
integer
Maximum spool number in current spool drawing
SMEMB
element(10000)
Immediate members in secondary hierarchy
SMNO
integer
SMODU number
SMOD
string
Sectioning mode
SMOM
real(3)
Start moment component
SOLFILLED
logical
Solid Filled Flag
SORF
element
Source reference (for automatic application)
SOUR
string(1000)
Source macro
SPBREF
element
Reference to boundary element
SPECIF
logical
True if outer panel contour on PS/SB are different
SPIN
string(4)
DRAFT user defined spindle symbol/skey name
SPINRE
element
Reference to external inventory element
SPKBRK
logical
ATTA flag to treat as a real element
SPKCHG
element
flag to show where a spec change occurs in a branch
SPKDI
real
Proportional distance of start point along Pline
SPLA
string
Name of spigot plate
SPLATE
word
Section plate
SPLH
string(120)
Old spooler head tube spool number
SPLMEM
element(1500)
Spooling table attribute on SPOOL or FIELD elements
SPLN
string(120)
Old spooler component spool number
SPLNUM
integer
Spool number
SPLP
string(120)
Spool number prefix
SPLPARENT
element(500)
elemtype
Branches referenced by a SPLDRG, SPOOL or FIELD
SPLT
string(120)
Old spooler tube spool number
SPLTBL
integer(2000)
Table linking SPOOL & FIELD elements to piping components
SPLVOLUME
real(3)
Volume of a SPOOL element
SPMA
real
word
Spec angle maximum answer
SPMACC
string(25)
Access authorization code
SPMACD
string(75)
Access authorization description
SPMALL
real
Structural Allowance
SPMAOF
real
Offset AFT
SPMARA
real
Area of face
SPMARE
real
Area of face
SPMATP
integer
Type of space arrangement
SPMBB
real(6)
Bounding box
SPMBIN
integer
Boundary identification number
SPMBNA
string(80)
Boundary name
SPMBOF
real
Offset BOT
SPMBOX
real(6)
Bounding box
SPMBR
element
Bounding reference
SPMCAS
real
Calculated steel paint area of space contents
SPMCDE
string(75)
Content description
SPMCFA
real
Floor area
SPMCLI
word(2000)
List of customer attributes for space
SPMCOL
integer
Colour
SPMCOS
real(3)
Calculated centre of steel structure
SPMCOV
pos
Centre of Volume
SPMCTY
string(25)
Content type code
SPMCWB
real
Calculated length of butt weld
SPMCWC
real
Calculated Weight of space Contents
SPMCWL
real
Calculated length of fillet weld
SPMCWS
real
Calculated Weight of steel structure
SPMDE
real
Density
SPMEAS
real
Estimated steel paint area of space contents
SPMEHC
real
Estimated HVAC Capacity
SPMEN
string(26)
Envelop name
SPMEPC
real
Estimated Power Consumption
SPMEWB
real
Estimated length of butt weld
SPMEWC
real
Estimated Weight of space Contents
SPMEWL
real
Estimated length of fillet weld
SPMEWS
real
Estimated weight of steel structure
SPMFAR
real
Face area
SPMFCL
string(20)
Fire class
SPMFLW
real
Full load weight
SPMFOF
real
Offset FWD
SPMFST
integer
Face state
SPMHSN
string(26)
Hull surface name
SPMLSC
string(25)
Space Category
SPMMVO
real
Total (moulded) volume
SPMNBI
integer
Next boundary identification number
SPMNOC
string(25)
Noise category code
SPMNOD
string(75)
Noise category description
SPMNVO
real
Net volume
SPMPED
real
Permeability Damage
SPMPER
real
Permeability
SPMPOF
real
Offset PS
SPMPP
real(5)
Precise properties
SPMPU
string(25)
Purpose code
SPMRDH
real
Required deck height
SPMRFA
real
Required floor area
SPMRSE
string(25)
Required service code
SPMRSN
string(26)
Reference surface name
SPMRTE
element
Reference to envelop space
SPMSAC
string(25)
Safety category code
SPMSAD
string(75)
Safety category description
SPMSAN
string(80)
Space arrangement name
SPMSBD
element(500)
Space boundary definitions
SPMSEC
string(25)
Security classification code
SPMSED
string(75)
Security classification description
SPMSFI
integer
Subface identification number
SPMSFP
element
Returns the space that contains the given point
SPMSOF
real
Offset SB
SPMSS
integer
Space state
SPMSTP
integer
User defined subtype
SPMSWT
integer
Type of space world
SPMTHC
string(25)
Thermal insulation code
SPMTHD
string(75)
Thermal insulation description
SPMTIC
string(25)
Compartment tightness code
SPMTID
string(75)
Compartment tightness description
SPMTOF
real
Offset TOP
SPMTOL
integer
Type of limits
SPMTYP
string(20)
Type of space world as enumerated
SPMVOI
integer
Space void marker
SPOONUMBER
string(120)
Spool number including spool prefix
SPOW
element
Reference of SPEC owning SPCO of branch members
SPPOSN
integer
Position number of spigot plate
SPPURP
word
Special purpose table attribute
SPRA
real
word
Spec angle answer
SPRB
real
word
Spec bore answer
SPRE
element
Component spec reference
SPSF
element
Sheet pointset reference
SPSP
string(2)
Old spooler spool prefix
SPTYPE
word
Type of element to be selected
SPWD
string
word
Spec text answer
SREF
string(12)
Source reference
SREL
integer
Start releases (packed)
SREVAY
element(50)
Sheet revisions array
SRFTRE
element
Reference to a SRFTRT element
SRTP
integer
Sorting priority for dimensions
SSLENGTH
real
Second side length
SSPLIT
logical
Spool Split
STACOM
string(1000)
Comment to the current status set
STAELE
real
Start Elevation
STAN
real
Start angle
STAP
real
Length of arrive straight tube
STAPOINT
integer
Cable Start connection point
STAREF
element
Cable Start reference
STASUS
logical
Current status suspended
STCD
string(120)
Symbol Code
STDEFREF
element
Status definition
STEREF
element(500)
Stencil reference array for schematic elements
STEX
string(120)
S Text string
STFC
real
Constant stretch factor
STFP
real
Proportional stretch factor
STILEN
real
integer
Stail length
STILEX
real
Stile Exit Width
STINCD
string(120)
Inside surface treatment symbol code
STINRF
element
Inside surface treatment reference
STITL
string(120)
Sheet title
STLE
real
Length of leave straight tube
STLPOS
element
Status Element reference
STLR
element
Steel Reference
STLSF
element
Database reference
STMF
element
Template selection pointer
STMPLS
element(10000)
List of STAMPs related to an MDB
STOCKL
real
Stock Length
STOUCD
string(120)
Outside Surface treatment symbol code
STOURF
element
Outside surface treatment reference
STPDBS
element(5000)
Stamps containing db
STPSES
integer(2000)
Sessions used in at least one stamp
STPUV
pos
Start point
STRCD
integer
STRCD
STRCON
string(120)
Stair Configuration
STRE
real
Spot value of stress
STREAT
string(26)
Surface treatment
STREV
string(120)
String value evaluation
STRJUS
word
Cable Way Justification Line
STRSTD
string(120)
Stair Standard
STRXP
integer(500)
String expression
STRXPL
logical
True if surface treatment explicitly defined
STSESS
integer
Database session number
STSP
element
Structural specification
STVASD
element(500)
Status types eligible
STVCOM
string
element
Status comment
STVDEMOTE
element
Demote Status Value
STVDSC
string
element
Status description
STVLNK
element
element
Status value Reference
STVLST
element(500)
Statuses assigned
STVMOD
string(120)
element
Date of last status modification
STVNAM
string
element
Status value name
STVNUM
integer
element
Status value
STVPROMOTE
element
Promote Status Value
STVREF
element
Value Ref
STVSUS
logical
element
Current status held
STVTRV
element(500)
Valid Transitions
STVUNR
element(500)
Unresolved Status refs
STVUSD
element(10000)
Elements having this status value
STVUSR
string(120)
element
User making last status modification
STVVAL
element
element
STYF
element
Rep style reference
STYP
string
SPECON type question
STYPDB
string
DB sub type
SUBRUL
integer(200)
attr
List of subrule indexes for given rule
SUFFIX
string(50)
Suffix
SUPP
string(120)
Supplier Name
SUPR
element
SUPREF
SURF
string(120)
Surface Preparation
SURMAT
string(100)
Surface Material
SURNOR
dir
pos, dir
Surface Normal
SURPNT
pos
pos, dir
Surface Point
SURPRE
string(100)
Surface Preparation
SVASPLANE
logical
Hull symbolic view as plane Y/N
SVASSEMBLIES
element(100)
Hull symbolic view assembly elements
SVAUTO
logical
Hull symbolic view auto Y/N
SVBLEXCLUDE
logical
Hull symbolic view exclude blocks Y/N
SVBLOCKS
element(100)
Hull symbolic view block elements
SVCAX
logical
Hull symbolic view coord axis Y/N
SVCOMNO
integer
Hull symbolic view component number
SVCOMTYPE
integer
Hull symbolic view component type
SVCROSSSYM
logical
Hull symbolic view cross sect symbol Y/N
SVCURTYPE
integer
Hull symbolic view curve type
SVCURVES
element(100)
Hull symbolic view curve elements
SVDBEFORE
string(20)
Hull symbolic view depth before
SVDBEHIND
string(20)
Hull symbolic view depth behind
SVDRACCOM
logical
Hull symbolic view draw accommodation Y/N
SVDRAINTERS
logical
Hull symbolic view draw inters Y/N
SVDRAP
logical
Hull symbolic view draw plane V
SVDRCWAY
logical
Hull symbolic view draw cableway Y/N
SVDREQUIP
logical
Hull symbolic view draw equip Y/N
SVDRPIPE
logical
Hull symbolic view draw pipe Y/N
SVDRPVOL
logical
Hull symbolic view draw pvol Y/N
SVDRSTRUCT
logical
Hull symbolic view draw structure Y/N
SVDRVENT
logical
Hull symbolic view draw ventilation Y/N
SVLOOKING
integer
Hull symbolic view looking direction
SVLXMAX
string(20)
Hull symbolic view xmax
SVLXMIN
string(20)
Hull symbolic view xmin
SVLYMAX
string(20)
Hull symbolic view ymax
SVLYMIN
string(20)
Hull symbolic view ymin
SVLZMAX
string(20)
Hull symbolic view zmax
SVLZMIN
string(20)
Hull symbolic view zmin
SVNAME
string(1000)
Hull symbolic view name
SVPANELS
element(100)
Hull symbolic view panel elements
SVPLEXCLUDE
logical
Hull symbolic view exclude panels Y/N
SVPLTYPE
integer
Hull symbolic view plane type
SVPLXORIGIN
string(20)
Hull symbolic view x1
SVPLXUAXIS
string(20)
Hull symbolic view x2
SVPLXVAXIS
string(20)
Hull symbolic view x3
SVPLYORIGIN
string(20)
Hull symbolic view y1
SVPLYUAXIS
string(20)
Hull symbolic view y2
SVPLYVAXIS
string(20)
Hull symbolic view y3
SVPLZORIGIN
string(20)
Hull symbolic view z1
SVPLZUAXIS
string(20)
Hull symbolic view z2
SVPLZVAXIS
string(20)
Hull symbolic view z3
SVPNAM
string(1000)
Hull symbolic view pan name
SVPONLY
logical
Hull symbolic view pan only
SVPOSCOAXIS
string(20)
Hull symbolic view coord axis pos
SVREFLECT
logical
Hull symbolic view reflect Y/N
SVRSO
logical
Hull symbolic view RSO Y/N
SVSCALE
real
Hull symbolic view scale
SVSHPROFILE
logical
Hull symbolic view profile Y/N
SVSHSEAM
logical
Hull symbolic view shell seam Y/N
SVSHTHICK
logical
Hull symbolic view shell thickness Y/N
SVTYPE
integer
Hull symbolic view type
SVWAY
element(50)
Sheet Views array
SWING
word
Swing
SYLBTA
word
SYLBTAble attribute
SYMBFG
logical
Symbol flag
SYMGRO
string(120)
Symbol Group
SYMLNS
integer
Side of direction vector
SYMM
integer
Symmetry code
SYMNAM
string(120)
Symbol Name
SYMXYZ
dir
Vector along symmetry line
SYSZ
real
Symbol size (uniform scaling)
SYTBOK
logical
SYLBTA attribute updated flag
SZDI
real
Start load point in section
