Data Model
Introduction to Attributes
List of All Attributes
: Attribute R
Attribute R
Attribute Name
Data Type
Qualifier
Description
RADD
real
Default Radius value
RADF
real
Radius attractor factor
RADI
real
Radius
RADISP
real(10000)
Radius Spacing
RADL
real(2)
Radius limits (Min/Max)
RADS
logical
Radius set flag - ignore Radius values if FALSE
RAILHE
real(15)
Heights of rails measured from path
RAILTR
real(100)
Rail Trim
RANANG
real(32)
elemtype
Range of available angles for bends and elbows
RANEQUIP
real
Range of the nearest equipment
RANRAD
real(32)
elemtype
Range of available radii
RATFAC
real
Rationalisation factor
RATI
real
Pressure rating
RATPOT
string(15)
Rationalisation post text
RATPRE
string(15)
Rationalisation pre text
RATTAL
element(500)
word
Rnode list
RATTAL
element(500)
word
Ratta list
RAWNAM
string(500)
Name only
RAWPLA
element
Raw Plate
RAWPRO
string(26)
Name of raw profile
RCOD
string
Direction of region vertical on sheet
RCOF
pos
Rough centre of gravity
RCOU
integer
Number of rules on element
RDEF
real(3)
Port rotation flexibility defaults
REACT
string(1000)
Reactance
READONLY
logical
Read only
REALEV
real
Real evaluation
REALXP
integer(500)
Real expression
RECOMM
string(256)
Release to 3D comment
REDATE
string(12)
Release to 3D date
REDREF
element
Reducer table reference
REDTYPE
integer
Reducer Type
REDXRF
element(500)
Return reference from Reducer Table element to SPECs
REF
element
Reference of the element
REFA
word
Reference attribute used in ports
REFI
integer
Reference array index
REFL
word(120)
Types of elements (including UDETs) that can be pointed to by a reference attribute
REFLCL
logical
True if reflected in CL
REFLEVEL
integer
Reference Level
REFMOD
integer
Reflection Mode
REFSIZ
integer
Reference size
REPCOU
integer
Rule Repeat Counter
REPSEQ
integer
Sequence no. for template repeat element
REPTXT
string
Reporter text used for element type
REQUIRED
logical
Action is not optional
RESIS
string(1000)
Resistance
RESO
real
Model Resolution (distance)
RESTAT
integer
Release to 3D status
REUSER
string(12)
Release to 3D user
REV
integer
Pipe Revision number
REVDIR
logical
Reverse Direction flag
REWIDTH
real
Reduced width
RFLAG
word
Type of real answer NONE, SINGle, RANGe or MULTi
RFLF
real(3)
Rotational spring values
RGBCOL
real(3)
RGB colour vector
RHOST
string(120)
Host computer name or IP address of remote machine
RINE
real(3)
Rotational inertia vector
RINS
real
Inside radius
RISE
real
Tread Rise
RLAC
integer(500)
Rule action array
RLEX
element(20)
Array of references of special rules to exclude
RLIM
real(6)
Rotation limits
RLIN
element(20)
Array of references of special rules to include
RLIS
word(200)
List of rules set
RLLO
integer(500)
Rule logical array
RLOC
integer
Branch Member Creation Status code (Router)
RLSE
integer(500)
Rule selection array
RMFL
real(6)
Rotational moment flexibility
RMOF
real(9)
Rough moments of inertia
RNAM
string(120)
Recipient name
RNGCON
element
Rung Connection
RNGOFF
real
Rung Offset
RNREF
element
Route Node reference
RNRIDF
real
Rung Rising Default
RNRIMA
real
Rung Rising Minimum
RNRIMI
real
Rung Rising Minimum
RNTYPE
word
RNode Type
ROBRRU
element(500)
Router Rules applying to a piping element or members
ROLEREF
element
Access Control role references from ACR
ROOMTY
string(120)
Room Type
RORIEN
logical
True if repeat item is re-orientated upon rotation
ROTN
real(3)
Rotation
ROUT
real
Outside radius
ROUTND
element(100)
Cable Preliminary route point
ROUTRE
element
Route reference
ROWCOL
integer
Row colour
ROWCON
integer
Row colour number
ROWNUM
integer
Pin row number
ROWSTREF
element
Row linestyle Reference
ROWSTY
integer
Row linestyle
RPARM
real(4)
Rest plate parameters
RPEN
integer
Pen for internal rows
RPLCOD
integer
Rest plate code
RPLNAM
string(26)
Rest plate name
RPLNUM
integer
Number of rest plates
RPLPOS
real(4)
Rest plate position
RPLSET
integer
Rest plate set
RPLTYP
integer
Rest plate type
RPLUSD
integer
Rest plates used
RPRE
real
Reference pressure
RPRO
real
word
Catalogue dataset property
RPTDAT
real(4)
Radial Dim Point 2D Data
RPTX
string(30)
Text used when presenting the attribute to the user
RRSF
element
Rep ruleset reference
RSBOX
real(6)
Bounding box of RSO
RSEQA
integer(500)
Sequence numbers for rule execution
RSEQFA
element(500)
Rule sequence ref array for local names
RSEQN
integer
Sequence number for rule execution
RSESS
string(120)
integer
Reason for creation of session
RSET
logical(3)
Rotation limits set flag - ignore values if FALSE
RSFFD
integer
Functional description on face
RSFMC
integer
Material code on face
RSFMS
string(256)
Material side on face
RSFMT
real
Material thickness on face
RSFSA
logical
Auto stiffening on face
RSFSD
string(256)
Profile dim on face
RSFSS
string(256)
Stiffener side on face
RSFST
integer
Profile type on face
RSFWT
logical
Watertight
RSLBRA
string(256)
Bracket instance at limit
RSLELE
element
Limiting element
RSLPRE
integer
Profile end definition at limit
RSPAN
element(1000)
Panel(s) defined on RSO
RSPLN
integer
Principal plane of RSO
RSRF
real
Rough surface area
RSTYP
integer
Type of RSO
RTEM
real
Reference temperature
RTEX
string(120)
R Text string
RTYP
string(12)
Restraint type
RULEER
string(300)
integer
Text of "nth" rule error
RULEMOD
logical
attr
True if rule modified this session
RULEMODC
logical
attr
True if rule modified since comparison date
RULEMODLIST
word(500)
integer
List of rules modified since given session
RULEMODLISTC
word(500)
List of rules modified since comparison date
RULLIM
real(6)
Ruler limits
RULRCO
integer
Ruler type code
RULSET
word(2000)
List of rules set
RULTCK
integer
Number of ticks between labelled ticks
RUNGS
integer
integer
Number of rungs
RUNGSP
real
Rung Spacing
RUSE
integer
True if PPROP/DPROP to be used as an RPROP in geomset/pointset attribute expression
RVAU
string(1000)
Revision author
RVDT
string(12)
Date of revision
RVOL
real
Rough gross volume
RVSN
string(1000)
Revision number
RVTM
string(120)
Time of revision
RWDOWN
integer(2)
Table linking RWELD elements to design WELD elements
RWDOWN
element
Reference of associated WELD of RWELD element
RWEI
real
Rough weight
RWIDTH
real
Rung Width
