Data Model
Introduction to Attributes
List of All Attributes
: Attribute P
Attribute P
Attribute Name
Data Type
Qualifier
Description
PAAX
string(30)
Direction of axis
PACTDI
dir
integer
Ppoint actual direction
PAGE
integer(50)
Page in diagram
PAINTO
string(26)
Painting other side
PAINTT
string(26)
Painting this side
PAIREF
element
Reference to a PAINT element
PALIG
real
Panel alignment
PALLAN
real
integer
Ppoint allowed angle
PANESI
real(2)
Panel Size
PANG
string(1000)
Angle subtended
PANREF
element
Panel reference
PANSCD
integer
Panel storing code
PANSID
integer
Side of panel
PANSTC
integer
Panel storing code
PARA
real(100)
Parameters
PARAL
logical
True if tap parallel to referred seam
PARCOLUMN
element
Parent column
PARENT
element
elemtype
Reference of ascendant element of specified type
PARM
real(6)
Parameters
PARNAM
string(256)
Part name
PARREF
element(10)
Part reference
PARTNUMBER
integer
Part number of a spooled component or leave tube
PASS
string(7)
Password
PASSQ
integer
Password Quality
PATADV
real
Line Pattern Advance value
PATDEF
integer(20)
Pattern Definition
PATH
element(500)
Path
PATHTM
real
Path time for selected burning machine
PATNAM
string
Pattern Name
PATOFF
real
Line Pattern Offset
PATREP
real
Pattern Repeat
PAXI
string(30)
Axial direction
PBAX
string(30)
Direction
PBBT
string(1000)
Bottom B length
PBDI
string(1000)
Distance to bottom surface
PBDM
string(1000)
Snout bottom diameter
PBENDNUMBER
integer
Spooling pulled bend number
PBOF
string(1000)
B offset
PBOP
pos
integer
Bottom of pipe
PBOR
string(1000)
Bore
PBTP
string(1000)
Top B length
PCAX
string(30)
Direction of C offset
PCBT
string(1000)
Bottom C length
PCODA
integer
Precision code angles
PCODE
integer
Precision code
PCODF
integer
Precision code fractions
PCODI
integer
Precision code imperial
PCODM
integer
Precision code metric
PCOF
string(1000)
C offset
PCON
string(1000)
Connection type
PCONDE
string(120)
integer
Ppoint connection description
PCORRO
real
integer
P Tube corrosion
PCPIDV
element(10000)
Enabled for project copy
PCPSET
element(10000)
PCREF
integer(4)
integer
Ppoint and ref of connected piping component
PCRFA
element(500)
All spools that contain this element
PCTP
string(1000)
Top C length
PCWALL
real
integer
Ppoint connect wall thickness
PDAREF
element
Pipe data table reference
PDEFI
string
Primitive Definition
PDEREF
element
integer
Pipe data element reference
PDIA
string(1000)
Diameter parameter
PDIR
dir
integer
Ppoint direction
PDIS
string(1000)
Distance parameter
PDTINT
integer(2)
Production date
PDTTXT
string(22)
Production date text
PDWGF
string(73)
DWG filename (with suffix)
PERS
real
Perspective angle
PFLALL
string(1000)
Flange allowance parameter
PFLOFF
string(1000)
Flange offset parameter
PFON
integer
Projection line text font
PFONTN
string(80)
Projection line text font name
PFRE
element
Pfitting reference for Cofittings
PFREQ
logical
Picture file required flag
PGRD
real
integer
Ppoint gradient
PHBO
real
Pipe head bore
PHBP
pos
Bottom of pipe head
PHCO
word
Pipe head connection type
PHDR
dir
Pipe head direction
PHEI
string(1000)
Height
PHGR
real
Pipe head gradient
PHOD
real
Pipe head outside diameter
PHPO
pos
Pipe head position
PHTP
pos
Top of pipe head
PICCOL
integer
Picture current colour
PICDMS
element
Picture current dimension style reference
PICF
string(73)
Picture filename
PICFD
logical
Picture file distribution flag
PICHTY
word
Hard type of picture
PICLBS
element
Picture current label style reference
PICLRF
element
Picture current layer reference
PICLST
integer
Picture current linestyle
PICORF
element
Picture current owner reference
PICSTY
word
Soft type of picture
PICTXS
element
Picture current text style reference
PICVWS
element
Picture current view style reference
PINDEN
real
Pin Density
PIPSYM
logical
Pipe-end symbol flag
PITCH
real(10)
Pitch of stair flight
PITCHO
real
Angular offset from ladder pitch
PJUS
string
Projection line text justification
PKDI
real
Proportional distance along Pline
PKEY
word
Pline identifier key
PLALEN
real
Raw plate length
PLANU
string(1000)
Planning Unit
PLANV
logical
Is Plan View
PLAREA
real
Area
PLATYP
string(26)
Type of plate e.g. Plate, Bracket, Clip,...
PLAWDT
real
Raw plate width
PLAX
string(120)
2D direction angle
PLCL
real
Projection line clearance
PLCLFL
logical
Proj. line clearance flag
PLCLTX
string(80)
Projection line clearance text
PLCN
logical
word
Pline centreline flag
PLCO
word
word
Pline connection
PLCOLO
integer
Projection line colour
PLCONU
integer
Projection line colour number
PLDE
string(120)
word
Pline description
PLDI
real(3)
Projection line direction
PLED
dir
Plane entry direction
PLEN
pos
word
Pline end
PLENCU
pos
word
Pline end, allowing for cutback
PLFG
logical
Plines flag
PLINON
logical
Pline-required flag
PLLE
integer(2)
word
Pline level
PLLS
word(100)
List of valid Plines
PLNA
word(100)
List of available Pline names
PLNCOL
integer
Pline colour
PLNCON
integer
Pline colour number
PLNP
integer
Pline pen
PLNSTREF
element
Pline linestyle Reference
PLNSTY
integer
Pline linestyle
PLOR
ori
word
Pline orientation
PLPM
word
Plane pipe packing method - nearest or weighted
PLPN
integer
Projection line pen
PLPP
word
Plane pipe positioning code word used by Router
PLPU
word
word
Pline purpose
PLRD
dir
Plane routine direction
PLREFS
element(5000)
Pline references
PLRF
element
Plane reference
PLSP
real
Projection line text line spacing
PLSPTX
string(80)
Proj line text line-spacing text
PLST
pos
word
Pline start
PLSTCU
pos
word
Pline start, allowing for cutback
PLSTREF
element
Projection linestyle Reference
PLSTYL
integer
PLTU
logical
word
Pline tube flag
PLTX
string(1000)
PLVI
word(200)
List of visible Plines
PLVIF
integer
word
Pline visibility flag
PLWW
word
Plane wall to wall positioning code used by Router
PMAX
integer
Maximum part number in current spool drawing
PMLFUN
string(120)
PML Function name
PMLNAM
string(120)
Name of Pmlobject
PMOD
string
Plane mode
PNAM
string(12)
Property description
PNTUV
pos
Point2D
PNTXYZ
pos
Point3D
POCK
word
Is a branch component in a pocket
POD
real
integer
Ppoint outside diameter
POEF
logical
Post-evaluation flag
POFF
string(1000)
Offset
POINUM
integer
Point Num
POIS
real
Spot value of Poissons ratio
POITYP
string(10)
Point type
POS
pos
Position
POSE
pos
End point position
POSEE
real
Easting of end point position
POSEU
real
Upping of end point position
POSEV
pos
Position evaluation
POSEY
real
Northing (Y coordinate) of end point position
POSF
logical
Positioning flag
POSFOR
string
Intelligent Text positional code word expansion style
POSL
word
Positioning line
POSN
real
Northing of position
POSNO
integer
Position number
POSREF
element
Reference to point
POSS
pos
Start point position
POSSE
real
Easting of start point position
POSSN
real
Northing of start point position
POSSU
real
Upping of start point position
POSTEX
real
Post Extension
POSTOF
real
Vertical post offset from the routing path
POSTSP
real
Default post spacing
POSU
real
Upping of position
POSX
real
Easting (X coordinate) of position
POSXP
integer(500)
Position expression
POWFAC
real
Powder point factor
PPANFL
real
Pipe Piece Angle between flanges
PPAREF
element
Pipe Piece Arrive Reference
PPBO
real
integer
Ppoint bore
PPBRAD
real(500)
Pipe piece bend radii
PPBRAT
real(500)
Pipe piece bend ratio
PPCNBD
logical
Pipe piece contains bends
PPCO
word
integer
Ppoint connection type
PPCOU
integer
Number of valid Ppoints
PPCUTL
real
Cut Length
PPDE
string(120)
integer
Ppoint description
PPDI
integer
Ppoint number for direction
PPEFR
logical
Leave flange required
PPER
element
Pipe piece end reference
PPEXST
logical
integer
True if Ppoint exists
PPFINL
real
Finished Length
PPFMCV
logical
Pipe piece fabrication machines verified
PPHEI
real
integer
Ppoint height
PPLREF
element
Pipe Piece Leave Reference
PPLS
integer(200)
List of valid Ppoints
PPMODI
logical
Pipe piece modified
PPNU
integer
Design PPoint/Port number
PPOFFT
real
integer
Ppoint offset
PPOS
pos
integer
Ppoint position
PPRFA
element(500)
All components in the PipePiece
PPRO
string(1000)
Parameterised Property Expression
PPSFR
logical
Arrive flange required
PPSK
word
integer
Ppoint pskey
PPSPEC
element
Pipe Piece Specification
PPSR
element
Pipe piece start reference
PPUR
word
integer
Ppoint purpose
PPVBMC
element
Return the bending machine IF the pipe piece is verified
PPVERI
word
Pipe piece verified
PPVI
integer(200)
List of visible Ppoints
PPVIF
integer
integer
Ppoint visibility flag
PPVWMC
element
Return the welding machine IF the pipe piece is verified
PPWID
real
integer
Ppoint width
PQAANG
real
integer
Angle between alignment direction of specified pp and adjacent component
PQANG
real
integer
Angle between specified Ppoint and adjacent component
PQBORE
logical
integer
TRUE if specified Ppoint has same bore as adjacent
PQCON
logical
integer
TRUE if leave Ppoint has Correct connection type
PQOFF
real
integer
Offset between specified Ppoint and adjacent component
PQUA
word
Property qualifier
PRAD
string(1000)
Radius
PRAV
real
Average pressure
PRBLNK
string
Primitive blanking flag
PRBMAR
real
Primitive blanking margin
PRBMPH
real
Primitive blanking margin physical
PRBMTX
string(80)
Primitive blanking margin text
PRDE
string(250)
word
Property default
PREF
logical
Pre-evaluation flag
PREFIX
string(50)
Prefix
PREPPR
string(26)
Preparation information
PREPT
real
Preparation time
PRES
real
Pressure
PRFC
string(1000)
Pressure factor
PRFELE
element
Cableway profile element
PRFG
logical
Profile flag
PRFL
string(120)
Profile
PRFOBS
integer
Cableway profile obstructions
PRICEE
real
Price estimate
PRIMDB
string
Global status of DB, primary or secondary
PRIMEM
logical
Primary member
PRIMSY
element
Reference of the primary system elements
PRIMTY
logical
True if element is primary
PRITYP
string(120)
Gpart Primary type
PRJD
string(120)
Project description
PRJID
string(8)
Project id. Available on STAT or GSTAT element
PRJL
logical
Project lock
PRJN
string(17)
Project number
PRJSTA
word
Access Control project status
PRLS
word(100)
List of valid properties - catalogue or design
PRMA
real
Maximum pressure
PRMDIR
dir
Primary Direction
PRMI
real
Minimum pressure
PRMLOC
element
Primary location
PRMMEM
logical
True if there are any primary elements amongst descendants
PRMOWN
element
Primary owning element (will be itself if primary)
PRMRF
element
Primary Location Element
PRMVI
logical
Draughting primitive visibility
PROCDE
string(600)
PROCess DEscription
PRODID
string(26)
Product id
PRODRF
element
Reference to Production Object
PRODUCTION
real
Production level radiation
PROJID
integer(3)
PROJID - on the DB element
PROLEN
real
Raw profile length
PROMIX
integer
Index of Promote Status Value
PROP
string(250)
word
Property value from catalogue or design dataset
PROPG
logical
DB propagation flag
PROPRE
real
attr
Calculated Property Real Attribute
PROSID
integer
Plate side with most profile markings
PRPU
word
word
Property purpose
PRTI
string(120)
word
Property title
PRTIDL
string(132)
Long part id
PRTIDM
string(132)
word
Module part id
PRTIDS
string(132)
Short part id
PRTLST
string(26)
Parts list name
PRTREF
element
Part reference
PRTRTX
string(1000)
word
Part element R text
PRTSTX
string(1000)
word
Part element S text
PRTTTX
string(1000)
word
Part element T text
PRTXRF
element(500)
Return reference from PART element to SPCOs
PRVRF
element
Reference to previous owner of DB
PRVSES
integer
integer
Previous Session to that specified
PSARFA
element(500)
Pipespool arrive references
PSATTS
word(500)
List of pseudo attributes
PSESS
integer
integer
Previous session number
PSFG
logical
Piping component symbol flag
PSIZE
real(2)
Panel size
PSKE
word
Key for ISODRAFT
PSLRFA
element(500)
Pipespool leave references
PSPE
element
Pipe specification
PSPIN
integer
Ppoint number showing position of spindle
PSTAT
integer
Plane status
PSTF
element
Pointset reference
PSTLENGTH
real
Pipe stock length
PSTR
element
Structural Pline set reference
PSTYP
word
Spool Type
PSVLD
logical
Pipespool valid
PTAN
string
Projection line text angle flag
PTBO
real
Pipe tail bore
PTBP
pos
Bottom of pipe tail
PTCDI
string(1000)
Parameterised direction
PTCH
real
Projection text character height
PTCHTX
string(80)
Proj text char height text
PTCO
word
Pipe tail connection type
PTCOLO
integer
Projection text colour
PTCONU
integer
Projection text colour number
PTCPOS
string(250)
Parameterised position
PTDI
string(1000)
Distance to top surface
PTDM
string(1000)
Snout top diameter
PTDR
dir
Pipe tail direction
PTDTRE
element
Part Data set reference
PTEM
real
Pipework temperature
PTEPOS
string(250)
Parameterised end position
PTFA
element(3)
Point references
PTGR
real
Pipe tail gradient
PTLH
real
Projection text letter height
PTNB
integer(20)
Old spooler bolt part number
PTNH
integer
Old spooler head tube part number
PTNO
integer
Old spooler component part number
PTNT
integer
Old spooler tube part number
PTOD
real
Pipe tail outside diameter
PTOF
real(2)
Projection line text offset
PTOFTX
string(80)
Projection line text offset text
PTOLER
real
Tolerance on a design property
PTOP
pos
integer
Top of pipe
PTPN
integer
Projection text pen
PTPO
pos
Pipe tail position
PTPTXT
string(26)
Profile type. e.g. Stiffener, Flange,...
PTRE
element
Point set reference
PTRF
element
Point reference
PTS
integer(6)
Line definition points
PTSP
string(120)
Paint specification
PTSPOS
string(250)
Parameterised start position
PTTP
pos
Top of pipe tail
PTYP
word
Property type
PUCD
string(120)
Paint Code
PUINCD
string(120)
Inside punch code
PUNCHT
real
Punching time
PUNI
string(32)
Data Property Units
PUOUCD
string(120)
Outside punch code
PURCH
string(26)
Purchase information
PURP
word
Description code word
PVIF
integer
PPoint/Pline visibility filter
PVNO
integer
Picture version number
PWALLT
real
integer
Ppoint wall thickness
PWAS
string(1000)
Percentage wastage factor
PWID
string(1000)
Width / Wall thickness
PWWFAC
real
Powder way factor
PX
string(1000)
Cartesian X position
PXBS
string(1000)
Inclination of bottom surface to local X axis
PXLE
string(1000)
X length
PXTS
string(1000)
Inclination of top surface to local X axis
PY
string(1000)
Cartesian Y position
PYBS
string(1000)
Inclination of bottom surface to local Y axis
PYLE
string(1000)
Y length
PYTS
string(1000)
Inclination of top surface to local Y axis
PZ
string(1000)
Cartesian Z position
PZAXI
string(30)
Alignment axial direction
PZDIR
dir
integer
Ppoint alignment direction
PZLE
string(1000)
Z length
