Data Model
Introduction to Attributes
List of All Attributes
: Attribute O
Attribute O
Attribute Name
Data Type
Qualifier
Description
OANG
real
Overlay sheet angle
OBCOLO
integer
Obscured face colour
OBCONU
integer
Obscured face colour number
OBFG
logical
Obstruction flag
OBJCD
integer(2)
Object codes
OBPN
integer
Obscured face pen
OBSDEP
real
Obstruction Depth
OBST
integer
Obstruction level
OBSTREF
element
Obscured face linestyle Reference
OBSTYL
integer
OBSWID
real
Obstruction Width
OCCTYP
string(50)
Occupancy Type
OCCUPA
real
Occupancy
OCOD
string
Hashed origin code
OCONE
integer
Objectcode 1
OCTWO
integer
Objectcode 2
OD
real
Outer Diameter
ODESP
real(100)
Owning design parameters
ODWGF
string(73)
Open DWG filename (No suffix)
OFFDIR
dir
Offset direction applied to repeat
OFFDIS
real
Offset distance applied to repeat elements
OFFSET
real
Offset
OFFTOL
string(1000)
PPoint offset tolerance
OFFTYP
word
Offset type: DELTA, LINEAR, RADIAL
OGDSTS
real(25)
Distances to openings
OGOING
real
Overall Going
OKCLA
logical
True if element may be claimed
OKCLH
logical
True if element and hierarchy may be claimed
OKDROP
logical
True if element may be dropped
OKDRPH
element(5000)
Primary elements preventing hierarchy drop
OKREL
logical
True if element may be released
OKRLEH
element(5000)
Primary elements preventing hierarchy release
OKRLEX
logical
True if element may be extract released
OKRLH
logical
True if element and hierarchy may be released
OKUPGD
logical
True if a Master DB that can be upgraded here
OLCOLO
integer
Outline colour
OLCONU
integer
Outline colour number
OLDKEY
integer
Old key
OLENGTH
real
Overall length
OLIS
word(2000)
List of all possible owner types
OLOFF
real
OffsetLine offset from baseline
OLPEN
integer
Outline pen
OLSTREF
element
Outline linestyle Reference
OLSTYL
integer
Outline linestyle
OMITFG
logical
Omission flag
ONPJ
pos
Owning neutral point of joint (steelwork)
ONPO
real(2)
ONTO Point, position of view in the region
ONPS
pos
Owning neutral point of section (steelwork)
OPAR
real(100)
Owning parameters - catalogue component
OPCLA
word
Claim Access Control Operation
OPCOP
word
Copy-From Access Control Operation
OPCRE
word
Create Access Control Operation
OPCREF
element
Offpage connector reference
OPDEL
word
Delete Access Control Operation
OPDI
dir
Origin plane direction
OPDRO
word
Drop Access Control Operation
OPERAT
string(26)
Operator
OPEXP
word
Export Access Control Operation
OPHEIG
real
Operational Height
OPISS
word
Issue Access Control Operation
OPLENG
real
Operational Length
OPMOD
word
Modify Access Control Operation
OPNSIZE
real(2)
Opening size
OPOS
pos
Overlay sheet position
OPOUT
word
Output (DATAL) Access Control Operation
OPREMA
real
Operating pres. max
OPREMI
real
Operating pres. min
OPTEMP
real
Operational temperature
OPWIDT
real
Operational Width
ORI
ori
Orientation
ORIA
real(3)
Orientation as angles
ORIF
logical
Orientation flag
ORIN
word
DRAFT user defined symbol orientation
ORISE
real
Overall Rising
ORNA
string(1000)
Originator text
ORRF
element
OSDWG
string(120)
AutoCAD overlay name
OSET
logical
Offset/VIEW position flag
OSFN
string(1024)
Overlay sheet file
OSHT
real
Overshoot
OSHTTX
string(80)
Overshoot text
OSLV
real(12)
Overlay sheet view layers visible
OSRF
element
Overlay sheet ref
OSTYPE
word
Short cut for "Type of owner"
OTMPMA
real
Operating temp. max
OTMPMI
real
Operating temp. min
OTRUNG
logical
Omit Top Rung
OUPRTR
element
Outside paint reference
OUTD
string(1000)
Outside diameter
OUTFRF
element
Reference of matching outfit object
OUTSD
string(1000)
Outside shield diameter
OVCWIDTH
real
Overall cables width
OVRSH
real
Overshoot (d-measure) for unsymmetrical flange
OWNC
word
Owning connection type
OWNER
element
Element owner in database hierarchy
OWNEXPRESSION
string(1000)
Owner expression
OWNEXTYPE
string(15)
Owner expression type
OWNLST
element(100)
Owning hierarchy
