Data Model
Introduction to Attributes
List of All Attributes
: Attribute N
Attribute N
Attribute Name
Data Type
Qualifier
Description
N
real
Position northing
NACCNT
integer
Non-additive changes count
NAME
string(500)
Name of the element
NAMEDB
string
DB name
NAMESQ
string(700)
Type. sequence number and name of element
NAMETY
string(700)
Type and name of the element
NAMN
string(500)
Name of the element (without leading slash)
NAMTOL
logical
True if name is too long
NAMTYP
string(700)
Type and full name of element
NANGLE
real
North angle
NARE
element
Reference to neutral axis
NBEVIT
real(2)
Pathtime except starts, I-bevel
NBEVXT
real(2)
Pathtime except starts, X-bevel
NBEVYT
real(2)
Pathtime except starts, Y-bevel
NBORE
real
Allowable Nominal Bore
NCHAR
integer
Number of label characters
NCOF
pos
Nett centre of gravity
NCOL
integer
Number of columns
NCONNE
integer
Mismatched connections. i.e. no valid backpointer
NCUTNT
integer
Number of cutouts and notches
NCUTS
integer
Number of cuts in a mitred bend
NDFLT
real
Numeric default value for a UDA
NDTINT
integer(2)
NC tape date
NDTTXT
string(22)
NC tape date text
NGMR
element
Negative geometry set reference
NGSD
integer
Number of GSDs
NHOLE
integer
Number of holes
NIDLAB
real
Pathtime except idle time for label
NIDLT
real(2)
NLCOLO
integer
Note colour
NLCONU
integer
Note colour number
NLOA
real
Nominal load
NLPN
integer
Note/framing pen
NLSTREF
element
Note linestyle Reference
NLSTRT
integer
Number of label starts
NLSTYL
integer
Note linestyle
NMOF
real(9)
Nett moments of inertia
NOCLIP
logical
View no clipping flag
NOCOL
integer
Number of pin jig columns
NODIMS
logical
No Dims Flag
NOEXTCREATION
logical
Location extract create suppression flag
NOFF
integer
Number off
NOFG
logical
Link constraint inversion flag
NOHLRF
logical
NoHLRFlag
NOISEC
string(26)
Noise category
NOLNKP
logical
Linked Documents distribution disabled
NOMARK
logical
True if unmarked
NOMBIN
real(200)
word
List of valid Nominal bores in Inches
NOMBMM
real(200)
word
List of valid Nominal bores in MM
NOMDIR
dir
Nominal slope direction
NOMREF
element
Nominal bore table reference
NOMXRF
element(500)
Return reference from NOMTAB element to SPECs
NOPGS
integer
Number of openings
NORM
dir
Plane normal
NOROW
integer
Number of pin jig rows
NORTHING
pos
Northing part expressed as a position
NOSOFF
real
Nosing Offset
NOTF
element
Cross-reference to NOTE/VNOT/SYTM
NOTREAD
integer
Number of treads
NPDESC
element(5000)
List of non primary offspring
NPILL
integer
Number of jig pillars
NPLDFA
string(80)
Nesting default file 1
NPLDFB
string(80)
Nesting default file 2
NPLIST
element(500)
All NATPs attached to route node
NPLMIR
integer
Quantity mirrored nested plates
NPLNOR
integer
Quantity normal nested plates
NPLTOT
integer
Total quantity nested plates
NPOS
pos
Position in owner
NPOSE
real
Easting of position wrt owner
NPOSN
real
Northing of position wrt owner
NPOSU
real
Upping of position wrt owner
NPPT
integer
Ppoint number
NPRSID
string(26)
Side of nested profile
NREL
integer
Nodal releases
NROW
integer
Number of rows
NRPARM
integer
Number of rest plate parameters
NRULEE
integer
Number of rule inconsistencies on element
NSESS
integer
Number of extant sessions
NSIZ
real
Nominal size
NSPE
element
Specification for NOZZLE
NSRF
real
Nett surface area
NSTART
integer(2)
Number of non-burning starts
NSTD
element
Non-standard bolt length (reference to DTAB)
NSTFAC
real
Number of starts - factor
NSTRT
integer(3)
Number of burning starts
NSTRTI
integer(2)
Number of burning starts I-bevel
NSTRTX
integer(2)
Number of burning starts X-bevel
NSTRTY
integer(2)
Number of burning starts Y-bevel
NTEXT
string(13)
Null text
NTRLEN
real
Neutral length
NUCDNA
real
Distance to nearest anchor
NUCDNE
real
Distance to the Nearest Edge
NUCDNR
element(2)
Nearest Adjacent Anchor
NULLRE
logical
attr
T/F on attributes that are null value references
NUMB
integer
Number
NUMBDB
integer
DB number
NUMCOR
integer
Number of cores in a cable
NUMOFF
integer
Number of Sheets in Drawing
NUSED
integer
Number of used raw plates
NVIEWF
string(73)
integer
Neutral viewer filename
NVOL
real
Nett volume
NWEI
real
Nett weight
NWELDS
integer
Number of attached welds on a piping component
NXTDBN
integer
Next DB number
NXTDBU
integer
Next Unique DB number
NXTEXN
integer
Next DB extract number
NXTFDB
integer
Next DB file and DB number
NXTFLN
integer
Next DB file number
NXTHB
element
Reference to next (future) hub
NXTKEY
integer
next UDA/UDET key
