Data Model
Introduction to Attributes
List of All Attributes
: Attribute M
Attribute M
Attribute Name
Data Type
Qualifier
Description
MACRID
string
Clip macro ID
MAINTENANCE
real
Maintenance level radiation
MAKER
string(100)
Maker
MANBLK
string
Name of owner block
MANCOG
pos
Center of gravity
MANPAN
string
Name of owner panel
MANTRA
real(16)
Transformation from local coordinate system
MANTYP
string(26)
Manufactured type e.g. Plane, Curved,...
MANU
string(120)
Manufacturer Name
MANWGH
real
Weight
MARKRF
element(100)
Cable Mark points
MARPTY
integer
Marine picture type
MATANG
real
Material Lay Angle
MATDEN
real
Material density
MATDIR
dir
Material direction
MATID
integer
Material ID
MATLEN
real
Material Length
MATN
string(1000)
Material Note
MATOVE
real
Material Overlap
MATPURPOSE
word
Material purpose
MATR
element
Material reference
MATWID
real
Material Width
MATX
element
Material text
MAXA
real
Maximum answer
MAXARE
real
Maximum area
MAXB
real
Maximum bore
MAXD
integer
DB hierarchy depth of lowest level item beneath element
MAXFIL
real
Maximum percentage fill level
MAXHUM
real
Maximum Humidity
MAXLP
real
Maximum length of pipe
MAXMIN
real(2)
Maximum and minimum values of design property
MAXOD
real
Maximum Outer Diameter
MAXPLN
pos
Maximum Plane Position
MAXPRE
real
Maximum Pressure
MAXREP
integer
Maximum number of Repeat items created
MAXSLO
real
Maximum pipe slope
MAXTEM
real
Maximum Temperature
MAXU
integer
Maximum number of user
MAXVOL
real
Maximum Volume
MAXWAT
real
Maximum Water Level
MBACK
element(10000)
elemtype
Members in reverse order
MBUFS
integer
Preferred buffer size in MBytes
MCBENT
logical
Machine bent
MCOLOUR
integer
Marker colour
MCONUM
integer
Marker colour number
MCOU
integer
elemtype
Number of Element Members of Given type
MDBCLS
element(1000)
List of MDBs in which DB is current
MDBLS
element(1000)
List of MDBs to which DB belongs
MDSYSF
element(10)
Reference Array of Model and Design Elements
MELRFA
element(500)
All components (non-tube) in the PipePiece
MEMB
element(10000)
elemtype
All members, or members of specific type
MEMDAB
element(10000)
Dabacon members
MEML
word
Member line for SCTNs
MEMNAM
string(120)
Member name
MEMTYP
string(256)
Member type array
MFAR
word(50)
Model Function Word array
MFFIND
element
Find Manufacturingpackage folder
MFLG
logical
Master link flag - SLAVE if FALSE
MIDP
pos
Section midpoint (steelwork)
MINARE
real
Minimum area
MINBEN
string(1000)
Minimum Bend Radius
MINFED
real(500)
Minimum feed values
MINFIL
real
Min Fill level on Cableway and Cabletray components
MINHUM
real
Minimum Humidity
MINLP
real
Minimum length of pipe
MINOD
real
Minimum Outer Diameter
MINPLN
pos
Minimum Plane Position
MINPOS
integer
Smallest position number of nested plate parts
MINPRE
real
Minimum Pressure
MINSLO
real
Minimum pipe slope
MINTEM
real
Minimum Temperature
MINVER
real
Minimum vertical pipe slope
MINVOL
real
Minimum Volume
MIRROR
logical
True if mirrored in local v-axis
MLEF
real
Minimum length excluding flange
MLIF
real
Minimum length including flange
MLIM
real(3)
Moment limits
MLNCOL
integer
Member-line colour
MLNCON
integer
Member-line colour number
MLNP
integer
Member line pen
MLNSTREF
element
Member-line linestyle Reference
MLNSTY
integer
MMBOR
real
MM Nominal Bore
MODATT
logical
attr
True if attribute of element can be modified
MODDEL
logical
attr
True if element can be deleted
MODERR
string(120)
attr
Returns the error text that would occur if attribute was modified
MODID
string(2000)
LMI Model ID
MODREF
element(100)
Model references
MODU
string(120)
Module
MOFI
pos
Moment of Inertia
MOME
real(3)
Moment
MOULEN
real
Mould length
MPEN
integer
Marker pen
MPFIND
element
MPKGFD
element
MPKGFI
integer(500)
Manufacturing Package Filter Expression
MPKGRF
element
Manufacturing Package Reference
MRGF
logical
ADP merge flag
MRGL
word
ADP merge level
MRKLEN
real
Total marking length
MRKR
word
3 way component marker
MRKST
integer
Number of starts for marking
MSESS
integer
attr
Last session number
MSTREF
element
Marker style Reference
MSTYID
integer
Marker style
MSTYLE
integer
Marker style
MSTYSZ
real
Marker size
MTBE
element
Material tube start. The first component, excluding ATTSs, for whom the LOFF is invalid or false
MTCL
real
Material tube centreline length.
MTEN
element
Material tube end. The first component, excluding ATTSs, for whom the LOFF is invalid or false
MTLCHE
string(80)
Matchline text character height as text
MTLCOL
integer
Matchline colour
MTLE
real
Material tube length for TUBI. Includes preceding bend length if bend is offline.
MTLFON
integer
Matchline text font
MTLLST
integer
Matchline linestyle
MTLSTZ
integer
Matchline line type zero is ByStyle
MTLTCH
real
MTLTCO
integer
Matchline text colour
MTLVIS
logical
Matchline visibility flag
MTOC
word
Material list control for components
MTOH
word
Material list control for head tube
MTOL
string(1000)
Material List Length
MTOPARTNUMBERS
integer(20)
Additional spooling item part numbers
MTOQ
string(1000)
Material take off quantity
MTOR
element(20)
Extra material list spec references
MTOT
word
Material list control for components leave tube
MTOX
integer(20)
Old spooler addition items
MTXR
element
Material text reference
MTXX
string(2000)
XTEXT of material text
MTXY
string(2000)
YTEXT of material text
MTXZ
string(2000)
ZTEXT of material text
MULT
real
Multiplier factor (unit definition)
MVER
element
Reference to Master Vertex
MYINSF
element
Surface Treatment Reference
MYOUSF
element
MYSRFT
element
word
