Data Model
Introduction to Attributes
List of All Attributes
: Attribute L
Attribute L
Attribute Name
Data Type
Qualifier
Description
LABOFFS
real(3)
Label offset
LABPOS
pos
Label position
LABST
integer
Number of starts for label signing
LACR
logical
Access Control on/off switch
LACTIV
logical
True if selectable : false = limbospec
LALCAB
element(500)
List arriving leaving cables on attached point
LALLAN
real
Leave Ppoint allowed angle
LASTM
string(120)
attr
Date of last modification
LAUTHU
logical
Login Authentication on/off switch
LAXE
ori
Local axes
LAYARF
element
Annotation Layer ruleset reference
LAYDRF
element
Design Layer ruleset reference
LAYOUT
logical
TRUE if element is layout mode
LAYTBF
element
Layer Table reference
LBBORE
logical
TRUE if Minor/Branch bore is in nominal bore table
LBGIMG
logical
Background image flag
LBOP
pos
Bottom of leave pipe
LBOR
real
Leave bore
LBSTRF
element
Label style reference
LCAS
integer
Load case number
LCHA
logical
Chain flag
LCIRCR
real(8)
Least circumscribed rectangle
LCKPSW
logical
Lock passwords for general users
LCLAIM
logical
Access Control Claim flag
LCLM
logical
True if element is claimed
LCLMH
logical
True if element and hierarchy claimed
LCLOSE
logical
Is this entity closed?
LCNFA
element(500)
Array of elements with local names
LCON
word
Leave connection type
LCORRO
real
Leave corrosion allowance
LCPOVWRITE
logical
Location Overwrite DB Users policy flag
LCTROL
logical
Controlled DB Flag
LCUTDI
dir
Lower Extension Cutting Direction
LDFLT
logical
logical default value for a UDA
LDI
dir
Leave direction
LDISP
logical
Display property flag for design datasets: True if property is shown on form
LDPR
real
word
Local design dataset property
LDRDIR
dir
Ladder Direction
LEAFS
real
Number of door leafs
LEAHEI
real
Leave height
LEAV
integer
Leave Ppoint
LEAWID
real
Leave width
LEND
logical
Line end
LENDTI
integer
Time out period for commands
LENG
real
Length
LENSEG
real
Length of segment
LETTER
string(50)
Letter
LEVE
integer(2)
Drawing level
LEVENL
integer
Time interval for Event Loop
LEVRFA
element(100)
References to levels serviced by stairwell
LEXTNS
real
Lower Extension Length
LFADIR
dir
Flight A Direction
LFAOFFSET
real
Landing Flight A Offset
LFBDIR
dir
Landing Flight B Direction
LFBOFFSET
real
Landing Flight B Offset
LFCOLG
integer
Glabel style frame colour
LFCOLO
integer
Label frame colour
LFCONU
integer
Label frame colour number
LFDP
element
word
LFPN
integer
Label frame pen
LFRA
logical
Frame flag
LFSTREF
element
Label frame linestyle Reference
LFSTYG
integer
GLabel style frame line type
LFSTYL
integer
LGAP
real
Last offset distance
LGOING
real(10)
Lower Tread Going
LGRD
real
Leave Ppoint gradient
LGTYPC
logical
Generic type is closed flag
LHBORE
logical
TRUE if Major/Header bore is in nominal bore table
LHEA
logical
Logical head flag
LHEI
real
Letter height
LHIDE
logical
Hide flag for catalogue datasets: True if property is not shown on form
LIGHTI
real
Lighting requirements
LIMI
real(6)
Volume of interest
LIMNUM
integer
Order number of limit
LINIT
logical
Location initialisation flag
LINKRE
element
Link reference
LINKS
element(5000)
Linked elements
LINKSN
integer
Linked session on parent extract
LINKXR
element(1000)
Referencing elements
LISS
logical
True if drawing has been issued
LIST
word(2000)
List of all possible member types
LLCL
real
Leader line clearance
LLCLTX
string(80)
Leader line clearance text
LLCOLG
integer
GLabel style leader colour
LLCOLO
integer
Label leader colour
LLCONU
integer
Label leader colour number
LLDIAGRAMS
string(2000)
Line list diagrams
LLEA
logical
Leader line flag
LLENG
real
Leave length
LLENTRY
logical
Is a line list entry - true or false
LLFROM
string(2000)
From column text for a line list
LLIS
word(2000)
List of all possible types in member hierarchy
LLPN
integer
Label leader pen
LLSTREF
element
Label leader linestyle Reference
LLSTYG
integer
GLabel style leader line type
LLSTYL
integer
LLTBRANCH
element
Line list tail branch
LLTO
string(2000)
To column text for a line list
LMAXTR
integer
Maximum number of retries for command
LMERDL
logical
Enable automatic merge of transaction db
LMERFAILURE
integer
Number of days Failed commands persist in Trans dB
LMERSUCCESS
integer
Number of days Successful commands persist in Trans dB
LMERTI
string(120)
Frequency of Auto Merge of Transaction DB
LMIRR
logical
True if Mirroring required
LNAME
string(20)
Local name as stored on template
LNDLEV
real(100)
Landing levels from owning element
LNFA
element(480)
Hidden Reference Array for linked Vertices
LNKCLS
element(500)
Classes referencing a DocLink
LNKDOC
element(500)
DocLinks referring to element
LNKELE
element(500)
Elements referencing a DocLink
LNKPRP
word
TRUE if item pointed to by descriptor should be propagated by Global
LNKREF
element
Reference internal document (drawing/sheet)
LNKRX
element
Reference to first location of a link
LNKRY
element
Reference to second location of a link
LNKUSE
word
Link Descriptor Usage
LNKWV
integer
Link weighting value
LNLST
string(2000)
List of local names for current template
LNOUPDATE
logical
DB propagation suppressed flag
LNPRXS
element(500)
Proxy items referring to element
LNTP
word
Line type
LOCA
string(120)
Location
LOCID
string(3)
Location identifier
LOCK
logical
True if element is locked
LOCPR
element(1000)
List of LOCs Primary at location
LOCRF
element
Location reference
LOCTYP
integer
Location
LOD
real
Leave Ppoint outside diameter
LOFF
logical
Offline flag
LOGEV
logical
Logical value evaluation
LOGFN
string(1024)
COMMS log file name
LOGLV
integer
COMMS log file level of detail
LOGMS
logical
COMMS log file active/inactive flag
LOGXP
integer(500)
Logical expression
LOHE
real
PLOOP height - from first PLOOP in owning panel
LOOS
logical
Loose
LOWGAP
real
Lower Gap
LOWPOS
pos
Point nearest workshop floor
LOWREF
element
References to lower exit level
LPITCH
real
Ladder Pitch
LPOS
pos
Leave position
LPOSE
real
Easting of leave position
LPOSN
real
Northing of leave position
LPOSU
real
Upping of leave position
LPRINT
logical
Printability flag
LPROT
logical
Protected DB Flag
LQAANG
real
Angle between alignment direction of leave Ppoint and next
LQANG
real
Angle between leave Ppoint and next component
LQBORE
logical
TRUE if leave Ppoint has same bore as next
LQCON
logical
TRUE if leave Ppoint has Correct connection type
LQOFF
real
Offset between leave Ppoint and next component
LRBORE
logical
TRUE if bores is in reducer table
LREF
element
Link reference
LREFO
logical
Database holds Reference data only flag
LRISE
real
Lower Tread Rise
LRUNG
logical
Last rung flag
LSELEC
logical
True if can be set Directly in Design
LSFBR
logical
Spooling marker for leave tube
LSHA
string
Leader shape code
LSPA
real
Text line spacing factor
LSPATX
string(80)
Character height text
LSRO
element
Leave rod specification
LSTR
logical
Stress flag
LSTU
element
Leave tube reference
LSTYNO
integer
Line Style Number
LSWID
real
Line Style Width
LSWKEY
string(120)
Line Style Width Key
LTAI
logical
Logical tail flag
LTBORE
logical
TRUE if bores is in branch (tee) table
LTCORR
real
Leave tube corrosion allowance
LTER
string
Label terminator code
LTERID
integer
Label terminator ID
LTHICK
real
Door leaf thickness
LTIMEI
integer
Time Interval between retries
LTITL
string(120)
Representation layer title
LTLE
real
Length of leave implied tube
LTOP
pos
Top of leave pipe
LTSTLEN
real
Leave Tube Stock Length
LTWALL
real
Leave tube wall thickness
LTWREF
element
Leave tube wall thickness reference
LVAR
logical
Variant Flag
LVDWPO
logical
TRUE if valid Draft pline point or ppoint
LVIS
logical
Visibility flag
LVOL
real(6)
Enclosing box volume in local coordinates
LWAITD
integer
Time interval between re-sending commands
LWALLT
real
Leave wall thickness
LWIDTH
real
Line Width
LWP
pos
Lower Working Point
LYCOL
integer
AutoCAD Layer Colour
LYCVFR
logical
AutoCAD Layer Current Viewport Freeze
LYDIR
dir
Leave Y axis direction on point
LYFRZE
logical
AutoCAD Layer Freeze flag
LYLOCK
logical
AutoCAD Layer Lock flag
LYLTYP
string(120)
AutoCAD Layer LineType
LYLWT
real
AutoCAD Layer LineWeight
LYNVFR
logical
AutoCAD Layer New Viewport Freeze
LYPFG
logical
AutoCAD Layer Plotting flag
LYPSTY
string(120)
AutoCAD Layer Plotter Style
LYVIS
logical
AutoCAD Layer Visibility Flag
LZCOLO
integer
Layer 0 colour
LZDIR
dir
Leave alignment direction
LZLSTY
integer
Layer 0 linestyle
LZLSTZ
integer
Layer 0 linestyle zero is solid
LZNPRI
logical
Layer 0 no printability flag
LZNVIS
logical
Layer 0 no visibility flag
LZPRIN
logical
Layer 0 printability flag
LZVIS
logical
Layer 0 visibility flag
