Data Model
Introduction to Attributes
List of All Attributes
: Attribute J
Attribute J
Attribute Name
Data Type
Qualifier
Description
JFRE
logical
True if Section position dominates a connection
JLIN
word
Joining line
JLNE
word
Joining line end
JLNS
word
Joining line start
JMAX
integer
Maximum joint number in current spool drawing
JNTBEV
real(2)
Joint part bevel code
JNTC
integer
Joint Code
JNTCOM
string(300)
Welded joint comment
JNTNAM
string(26)
Welded joint name
JNTNUMBER
integer
Joint number
JNTORF
element(1500)
Joint owners attribute on IJOINT elements
JNTOWN
integer(8)
Table linking IJOINT elements to piping components
JNTREF
element
integer
Return reference from Ppoint to ijoint element
JNTTHK
real(2)
Joint part thickness
JNTTSL
real
Total welded joint suspension length
JNTTWL
real
Total welded joint length
JNTTYP
string(26)
Welded joint type
JNUM
integer(2)
Old spooler joint number
JOIE
element
End joint
JOIP
word(2)
Old spooler joint number prefix
JOIS
element
Start joint
JUSL
word
Justification Pline
JUST
string
Justification
