Data Model
Introduction to Attributes
List of All Attributes
: Attribute I
Attribute I
Attribute Name
Data Type
Qualifier
Description
IAKEY
integer
Integer attribute key
IALIGN
integer
Integer vertical alignment
IBLNAM
string
Name of idealised block
ICAT
element
Insulation catalogue reference
ICLASS
string(120)
Interference class
ICLMO
integer
Centreline mode as integer
ICON
string(120)
ICON
ICONL
string(120)
ICONL
ICONN
integer
COMMS connection type (0/1 = on/off-line)
ICONS
string(120)
ICONS
ICOTYP
string(300)
Icon used for element
ICURF
integer
Integer curve fitting code: 1 default, 2 cubicfit
IDENT
string
Panel identification string
IDET
element
Insulation detail text reference
IDFLA
integer
Integer radial dimension type flag
IDLABL
real
Length of label idle movement
IDLFAC
real
Idle movement factor
IDLFG
integer
Integer linear/angular dimension line flag
IDLL
real(3)
Burning idle length
IDLLEN
real(2)
Non-burning idle length
IDLN
element
Drawlist name reference
IDLX
string(120)
Drawlist name (as text)
IDNM
element
Design data or catalogue component
IDNX
string(120)
Design data or catalogue component (as text)
IDRT
string(2000)
Insulation detail RTEXT
IDSPU
integer
Specified unique identifier
IDST
string(2000)
Insulation detail STEXT
IDSTY
integer
Integer radial dimension style flag
IDTAN
integer
Integer dimension text angle flag
IDTANA
integer
Integer dim. text angle flag style angular
IDTANL
integer
Integer dim. text angle flag style linear
IDTANR
integer
Integer dim. text angle flag style radiant
IDTER
integer
Integer dimension terminator code
IDTFL
integer
Integer dimension text radius flag
IDTT
string(2000)
Insulation detail TTEXT
IDTUL
integer
Integer dimension text underlining flag
IFTER
integer
Integer first dimension terminator code
IGAP
real
Intermediate offset distance
IGNDUN
logical
Ignore DUnion flag
IJUST
integer
Integer justification
ILSHA
integer
Leader shape code
ILTER
integer
Integer label terminator code
IMAT
element
Insulation material text reference
IMGDAT
integer(8192)
Image data
IMGSCA
real
Image scale
IMPED
string(1000)
Impedance
IMXT
string(2000)
Insulation material XTEXT
IMYT
string(2000)
Insulation material YTEXT
IMZT
string(2000)
Insulation material ZTEXT
INCBOR
real
Inch Nominal Bore
INCFLU
element(500)
Additional elements to include for flush
INCL
real
Inclination angle
INFA
string(120)
Client info - Project Name
INFB
string(120)
Comment - Project Message
INFG
logical
Insulation flag
INFOTE
string(120)
Infotext
INIVAL
element
Initial Value
INLEN
real
Insulation length
INMTRF
element
INSMAT Reference
INPINDEN
real
Insulation pin density (Area)
INPINLEN
real
Pin length
INPINT
string(120)
Insulation pin type
INPRTR
element
Inside paint reference
INRE
element
Insulation reference
INRF
element
Array of Inventory Items
INSARE
real
Insulation requirement area
INSC
string(120)
Inspection schedule
INSL
logical
DRAFT user defined symbol insulation flag
INSTNC
string
Bracket instance name
INSTOPTIONS
string(120)
Installation Options
INSURE
element
Reference to a INSCMP element
INSUTY
string(120)
Insulation type
INSYST
element(500)
Reference Array of all SYSGRPs Elements
INTHK
real
Insulation thickness
INTSEN
logical
Installation Sense - true if clockwise
INTY
word
Inventory item type
INVF
element(500)
INVI
logical(500)
Visibility state
INVREF
logical
attr
T/F on attributes that are invalid references
IOCOD
integer
Hashed origin code
IPAR
real(30)
Parameters of the insulation catalogue component
IPATNAM
integer
Integer pattern Name
IPJUST
integer
Integer pjustification
IPMOD
integer
Plane mode as integer
IPRBLN
integer
Integer primitive blanking flag
IPRE
real
Internal pressure
IPTAN
integer
Integer projection line text angle flag
IRCOD
integer
Integer direction of region vertical on sheet
IRNO
string
ISO-IR number
ISALLO
logical
True if database is allocated at this location
ISCOPY
logical
True if a copy DB
ISDBFR
logical
True if database is foreign
ISDBPR
logical
True if database is primary for global working
ISDRDB
logical
True if database has drawings
ISECPT
pos
word, integer
Intersection point
ISENS
integer
Integer sense
ISEXAP
logical
True if extract ancestry is primary here
ISEXCP
logical
True if all extract children are primary here
ISEXFP
logical
True if extract family is primary here
ISEXMP
logical
True if extract master is primary here
ISEXOP
logical
True if extract owner is primary here
ISEXTR
logical
True if an extract
ISFOR
logical
ISKEYDB
logical
Does ukey incorporate DB number
ISLNKD
logical
True if database may have Linked documents
ISLOADED
logical
True if Sheet is loaded
ISMAST
logical
True if a Master DB, i.e. top level extract
ISNAMED
logical
True if element is named
ISOHIDDEN
logical
Isohidden flag
ISPE
element
Insulation spec reference
ISPICF
logical
Picture has File
ISPR
element
Insulation specification component reference
ISPRIM
logical
True if database is primary at this location
ISSUE
logical
True if drawing has been issued
ISUPGD
logical
True if Upgrade is required for DB
ISWORK
logical
True if a working extract
ITCOD
integer
Hashed origin code
ITLE
real
Length of implied tube
ITMTBL
integer(2000)
Table linking AITEMS elements to piping components
ITPS
pos
Position of implied tube
ITXALIGN
integer
Integer text vertical alignment
IVTYP
integer
Integer type of design view
IWDORF
element(1500)
Weld owners attribute on IWELD elements
IWDOWN
integer(8)
Table linking IWELD elements to piping components
