Data Model
Introduction to Attributes
List of All Attributes
: Attribute H
Attribute H
Attribute Name
Data Type
Qualifier
Description
HANGLE
real
Hatching Angle
HAZARD
string(120)
Hazard
HAZTYP
string(120)
Hazard Description
HBLBOX
real(6)
Block box
HBOR
real
Head bore
HCCNT
integer
Header/Extract list changes count
HCOFG
pos
computed hull item centre of gravity
HCON
word
Head connection type
HCORRO
real
Head Corrosion
HCREF
element(10)
Head connections
HDBREF
element
Generic Hull DB Ref
HDCONN
element(500)
List of elements connected to branch head
HDIR
dir
Head direction
HDIST
real
Horizontal Distance
HDMF
element(2)
ISODRAFT Reference Dimension attribute
HDMT
word(2)
HDREF
element(500)
List of attachment connected to attachment
HDUPLI
element(10000)
integer
Duplicates of the current element (checking members)
HEADCL
real
Head Clearance
HEADRO
real
Headroom
HEATT
integer
Heat Treatment
HEIARR
real(10)
Height array
HEID
real
Default Height value
HEIF
real
Height attractor factor
HEIG
real
Height
HEIL
real(2)
Height limits (Min/Max)
HEIS
logical
Height set flag - ignore Height values if FALSE
HEND
string
Connection at other end of HREF (HEAD or TAIL)
HGHT
real
Height
HGSIDE
word
Hinge side
HHBO
real
Hanger head bore
HHBP
pos
Bottom of hanger head
HHCO
word
Hanger head connection type
HHDR
dir
Hanger head direction
HHGR
real
Hanger head gradient
HHOD
real
Hanger head outside diameter
HHPO
pos
Hanger head position
HHTP
pos
Top of hanger head
HIERARCHY
element(5000)
Structural connections
HIST
integer(120)
attr
History of sessions in which element or specified attribute were made
HLCOLO
string
Hull Colour
HLIS
word(2000)
List of all possible types in owning hierarchy
HLSTREF
element
Hatching linestyle Reference
HLSTYLE
integer
Hatching linestyle
HMAV
real
Average humidity
HMMA
real
Maximum humidity
HMMI
real
Minimum humidity
HNCKEY
integer
Hole Notch Cutout Key
HNODEL
element(500)
Hnode list
HOFFSE
real
Hatching Line Offset
HOLGRD
logical
True if any hole in the plate should be ground
HOOPSP
real
Hoop Spacing
HPATNO
integer
Hatch Pattern Number
HPOS
pos
Head position
HPOSE
real
Easting of head position
HPOSN
real
Northing of head position
HPOSU
real
Upping of head position
HPREF
element
Head point reference
HREF
element
Head reference
HREL
logical
Branch Member Head relative flag (Router)
HRJUSL
word
Handrail Justification Line
HROBS
real
Handrail Obstruction
HROFF
real
Handrail Offset
HRSDIS
real
Handrail Start Distance
HRSF
element
Hatch ruleset reference
HRSTAR
real
Handrail Start Height
HSARFA
element(500)
HVACSpool arrive references
HSEPAR
real
Hatching Line Separation
HSLRFA
element(500)
HVACSpool leave references
HSPE
element
Hanger specification
HSRFA
real
Computed Hull item surface area
HSRO
element
Headrod specification
HSTU
element
Head tube specification
HSTYF
element
Hatch style reference
HTBO
real
Hanger tail bore
HTBP
pos
Bottom of hanger tail
HTCO
word
Hanger tail connection type
HTDR
dir
Hanger tail direction
HTGR
real
Hanger tail gradient
HTOD
real
Hanger tail outside diameter
HTPO
pos
Hanger tail position
HTPREF
element
Topology reference
HTTP
pos
Top of hanger tail
HTYP
word
Hanger type
HUBRF
element
Reference to the hub location
HULAPP
logical
Hull applicable Geometry
HULCNT
integer
Size of hull array/collection
HULLDE
logical
True if element is a hull design item
HULLOB
element
Hull object reference
HULLPR
logical
True if element is a hull production item
HULOC
string
Location
HUMIDI
real
Design Humidity
HUMIRR
logical
True if mirrored in local v-axis
HUMVW
string
Model View
HUREFL
logical
Reflected
HUREPL
element
Replica
HUSYMM
logical
Symmetrical
HVOLU
real
Computed Hull Item volume
HWALLT
real
Head wall thickness
HWRF
element
Head Working Point (Router)
