Data Model
Introduction to Attributes
List of All Attributes
: Attribute G
Attribute G
Attribute Name
Data Type
Qualifier
Description
GANGLE
real
General Angle
GAPALL
string(1000)
Gap Allowance
GAPF
real
First offset distance
GAPI
real
Intermediate offset distance
GAPS
real(30)
integer
Projection line gap array
GAREA
real
Ceiling Grid Area
GASTIG
logical
Gas Tight
GATECO
string(120)
Gate Configuration
GATEHEIGHT
real
Gate Height
GATESI
real(2)
Gate Size
GATEWD
real
Gate Height
GBOX
real
Box gap
GBOXTX
string(80)
Box gap text
GCOF
pos
Gross centre of gravity
GDEFIN
integer(100)
Glyph Outline Definition
GDIAM
integer
Glyph Circle Diameter
GENGT
word
Geometry type
GENSTR
string
integer
General strings
GENTYP
word
Type of geometry
GEODEP
element(5000)
Direct geometrical dependencies
GEOM
integer
Geometry Modified- Not directly queryable
GFILLD
logical
Glyph Primitive Filled Flag
GHEIGH
real
Gate Height
GLBSTR
logical
True if Project has Global structure
GLBVER
string(120)
Global version string
GLINKP
logical
Project has Linked Documents distribution enabled
GLYNO
integer
Glyph Number
GLYNUM
integer
Glyph Number
GLYREF
element
Glyph Reference
GMOF
real(9)
Gross moments of inertia
GMRE
element
Geometry set reference
GOBREF
element
Generating reference
GOFFS
integer(2)
Glyph Primitive offset
GOING
real(10)
Tread Going
GPPRXS
element(500)
Group proxy items referring to element
GPSTR
string
General purpose strings
GRADE
real
Steel grade
GRAXE
integer
Grid axes (internal)
GRDAXE
string
Grid axes
GRDDIR
dir
Grid direction
GRDE
real
Gradient of implied tube. Gradient is the vertical rise(fall) divided by the horizontal distance.
GRDID
string(20)
Grid Identifier
GRDLBL
string(20)
Grid Label
GRDLID
integer(2)
Gridline Identifier
GRDLXP
real
Proportion along X gridline from Gridline ID
GRDLYP
real
Proportion along Y gridline from Gridline ID
GRDOFF
real
Grid offset
GRDPOS
pos
Grid Position
GRDXSP
real(10000)
Grid X Spacing
GRDYSP
real(10000)
Grid Y Spacing
GRIDNM
element
Design grid reference
GRIDNX
string(120)
Design element as text
GRIND
real
Grinding info
GRIP
real
Minimum distance between bends
GROUPS
element(500)
GPSETs in which element occurs
GRPRF
element
Reference to group (owner of location)
GRSYS
element
Grid system reference
GSRF
real
Gross surface area
GSTR
element
Structural geometry set reference
GTAREAS
element(5000)
All areas that fully or partially enclose element
GTEXAREAS
element(5000)
All areas that fully enclose element
GTGROUPS
element(5000)
GTROOM
element(5000)
GTXT
string(120)
Text storing rule to generate Inventory List
GTYP
word
Generic type
GVOL
real
Gross volume
GWEI
real
Gross weight
GWIDTH
real
Gate Width
GXLEN
integer
Glyph Rectangle XLength
GXYOFF
real(2)
Grid XY Offset
GYLEN
integer
Glyph Rectangle YLength
