Data Model
Introduction to Attributes
List of All Attributes
: Attribute F
Attribute F
Attribute Name
Data Type
Qualifier
Description
FAAN
integer
Skew angle for font file
FACODE
string(100)
Facode
FAILCO
integer
FailCond
FAREA
string(5)
Construction area
FCDATE
integer(2)
File creation date
FCENTRE
pos
Centre of fillet arc
FCLXSP
real(100)
Spacing between stair flights in the X direction of the tower
FCLYSP
real(100)
Spacing between stair flights in the Y direction of the tower
FCMEAS
real
Flange correction measure
FCODE
string
Face code
FCOE
real(3)
Friction coefficient
FCOLOUR
integer
Fill colour
FCONUM
integer
Fill colour number
FCPY
element
Forward copy reference
FDEPD
string(250)
word
Formatted Local Design Property Default Value
FDEPR
string(250)
word
Formatted Local Design Property Value
FDRA
string(32)
Isometric drawing number
FEDEXS
real(500)
Feed excess values
FEMCOL
integer
FEM image object colour
FEND
pos
Fillet arc position
FEQDES
string(120)
From Equipment Description
FFCOLO
integer
Front-face colour
FFCONU
integer
Front-face colour number
FFLEXT
real
Edge Extension Around Floor layer
FFPN
integer
Front-face pen
FFSTREF
element
Front-face linestyle Reference
FFSTYL
integer
FGAP
real
First offset distance
FGRF
element
Reference to boundary faces
FILCHK
logical
FILCHK (true if fill level check is enabled )
FILEEX
logical
True if DB file exists and is valid
FILENAME
string
DB filename
FILL
logical
DRAFT user defined symbol fill flag
Fill level check
logical
Fill level check
FILLDI
word
Fill direction
FILREF
element(500)
Sorted references to attachment points with ascending order of fill level greater then 0
FILTOPERATOR
string(25)
Filter operator
FILTVALUE
string(1000)
Filter value
FINO
integer
File number
FINPUT
string(120)
Input by
FIRE
real
Fire resistance
FIRERATING
string(120)
Fire rating
FISSUE
string(12)
Current pipe spec issue
FITLEN
real
Length of branch fitting
FIXT
string(12)
Structural fixity
FLALLO
real
Flange allowance
FLATYP
integer
Flange type
FLCARE
real
Floor cover area
FLCSTHICKNESS
real
Floor cover thickness
FLCVOL
real
Floor cover volume
FLEN
string(1024)
External file name
FLEVEL
real
integer
Fill level at route node
FLIM
real(3)
Force limit
FLLARE
real
Floor layer area
FLLTHK
real
Floor layer thickness
FLLVOL
real
Floor layer volume
FLNM
string(700)
Full name of the element
FLNN
string(700)
Full name of the element (without leading slash)
FLOFFS
real
Flange offset
FLOW
word
Flow direction
FLRCOD
string(120)
Floor Code
FLRECC
logical
Flare Eccentricity
FLRELE
real
Floor Elevation
FLRELV
real
Floor elevation
FLRHEI
real
Floor Height
FLROFF
real
Flare Offset
FLRTYP
string(120)
Floor Type
FLTDIR
dir
Stairflight Direction
FLUR
element
Fluid reference
FLWA
logical
DRAFT user defined symbol flow arrow
FMID
pos
Middle point of fillet arc
FNAM
string(1024)
Filename
FNCCD
integer
Functional description code
FNCTXT
string(80)
FNMA
string(32)
Standard font file name
FNMB
string(32)
Bold font file name
FNTD
string(32)
Font directory
FOLDED
logical
True if folded
FONT
integer
Text font
FONTG
integer
GLabel style text font
FONTN
string(80)
Font name
FOOTRO
real
Foot Room
FORC
real(3)
Force vector
FOREIGN
string
DB foreign/local
FPATH
string(256)
File path
FPEN
integer
Fill pen
FPLINE
string(32)
Process line number
FPON
integer
FROM port number
FPRDE
string(250)
word
Formatted property default
FPROP
string(250)
word
Formatted property value from dataset
FRAD
real
Fillet radius
FRDR
string(32)
Reference drawings
FREF
element
Fitting reference
FREV
string(4)
Isometric drawing revision
FRMSCL
real
Form scale
FRPO
pos
Eye point
FRSTW
element
word
Reference of first world of given DB type in current MDB
FSPOST
real
Distance to the first post
FSTART
pos
Fillet start position
FSTAT
string(15)
Fstatus
FSTNUM
integer
Fill style number
FSTREF
element
Fill style Reference
FSTYLE
integer
Fill style
FSTYNO
integer
Fill Style Number
FTCDD
string(250)
word
Formatted Current Design Property Default Value
FTCDP
string(250)
word
Formatted Current Design Property Value
FTER
string
First dimension terminator code
FTERID
integer
First terminator ID
FTERSA
integer
Dimension first term. code style angular FTERSA
FTERSL
integer
Dimension first term. code style linear FTERSL
FTHICKNESS
real
Stair Flight Thickness
FULLT
string
type of the element
FULSYS
string
Type of the element, ignoring UDET, not truncated
FUNC
string(120)
Function
FUNI
integer
FUNIT
FURNRF
element
Furniture Reference
