Data Model
Introduction to Attributes
List of All Attributes
: Attribute E
Attribute E
Attribute Name
Data Type
Qualifier
Description
E
real
Position easting
EASTING
pos
Easting part expressed as a position
ECCE
pos
Eccentricity (steelwork)
ECCJ
pos
Eccentricity of joint (steelwork)
ECLASS
word(100)
Access Control Element class
ECRFA
element(500)
Equipment connection reference array
EDGELE
real
Edge Length
EDISTA
real
Vertical Distance of End
EDPUV
pos
End point
EFAC
string(1000)
E-factor
EFOR
real(3)
End force vector components
ELCXRF
element(500)
Return reference from CABLE element to ELCONN element
ELDATA
integer(8192)
data
ELDSZ
integer
DataSize
ELECRE
logical
integer
True if created since given session
ELECREC
logical
True if created since comparison date
ELEDEL
logical
integer
True if deleted since given session
ELEDELC
logical
True if deleted since comparison date
ELEL
word(200)
Types of elements, including UDETs, to which this applies
ELEMOD
logical
integer
True if modified since given session
ELEMODC
logical
True if modified since comparison date
ELEPTR
integer
Elemp
ELESZ
integer
Size
ELEVAT
real
Elevation
ELEVV
logical
Is Elevation View
ELRATI
real
Electrical Rating
ELTYPC
word
Element type
ELVRSN
integer
Element version
EMOM
real(3)
End moment components
ENCODB
string
DB Encoding
ENDA
real
End angle
ENDELE
real
End Elevation
ENDOFF
real
Offset of the end of section
ENDPOINT
integer
Cable End connection point
ENDPOS
pos
End Position
ENDREF
element
Cable End reference
ENGLNK
element
Engineering Element Link
ENGTYP
string(2000)
Datasheet engineering type
EPARAM
real(6)
Evaluated parameters
EPKDI
real
Proportional distance of end point along Pline
EPOSTO
real
End post tangent offset
EREC
integer
Erection class
EREL
integer
End releases (packed)
ETEX
string(1000)
Example text
EVITXP
string(1500)
Evaluated intelligent text for projection line
EVITXT
string(1500)
EVOL
real(6)
Enclosing box volume in given coordinates
EXBTEX
string(1500)
Expanded annotation text
EXCESS
real
Excess
EXCLFR
logical
True if element claimed from this extract. Only True for Primary elements
EXCLFT
real
Excess on left side of seam
EXCLHI
element(5000)
Primary elements in descendant hierarchy claimed to this extract(includes this element)
EXCLPA
logical
True if element claimed to Parent extract. Only True for Primary elements
EXCLTO
logical
True if element claimed to this extract. Only True for Primary elements
EXCPRM
element(8191)
Primary locations of extract children
EXCRGT
real
Excess on right side of seam
EXCTLF
integer
Excess type on left side of seam
EXCTRG
integer
Excess type on right side of seam
EXDIST
real
Exit Top Distance
EXDMTX
string(1500)
Expanded dimension text
EXECAFTER
string(512)
Exec file after DB propagation
EXECBEFORE
string(512)
Exec file before DB propagation
EXEXTE
real
Exit Extension
EXEXTN
real
Exit Extension
EXFI
integer
Extract file number
EXHCNC
element(5000)
As EXTCNC, but repeat test for all descendents
EXHCNN
element(5000)
As EXTCNN, but repeat test for all descendents
EXHCON
element(5000)
As EXTCON, but repeat test for all descendents
EXHEIG
real
Exit Height
EXHRCN
element(5000)
As EXRCN, but repeat test for all descendents
EXHRCO
element(5000)
As EXTRCO, but repeat test for all descendents
EXMOC
logical
As EXMOD but ignoring changes to "noclaim" attributes and member lists
EXMOD
logical
True if element modified in this extract
EXNCLH
element(5000)
Primary elements in descendant hierarchy not claimed to this extract
EXOPRM
element
Primary location of extract owner
EXPA
real
Spot value of expansion coefficient
EXPIRY
string(50)
Protected DB Expiry date
EXPLTX
string(1500)
Expanded projection line text
EXPMOC
logical
As EXPMOD but ignoring changes to "noclaim" attributes and member lists
EXPMOD
logical
True if primary and element or non-primary descendants have been modified in this extract
EXPRESSION
string(1000)
PML or XPath Expression to be executed
EXPTYPE
string(15)
Expression syntax. Either PML or XPath
EXTALS
element(8191)
Extract ancestors
EXTCLS
element(8191)
Extract children
EXTCNC
element(5000)
As EXTCON but excluding non modified elements
EXTCNN
element(5000)
As EXTCON but excluding modified elements
EXTCON
element(5000)
Primary elements connected/disconnected from element or non primary descendents in extract
EXTDES
element(8191)
Extract descendants
EXTDIR
string(10)
Direction of ladder exit
EXTFAM
element(8191)
Extract family
EXTHI
integer
Location extract number range, high limit
EXTLO
integer
Location extract number range, low limit
EXTMAS
element
Extract master
EXTNO
integer
Extract number
EXTNSN
real
Extension
EXTOFF
real
Exit Offset
EXTOWN
element
Extract owner
EXTRC
string(120)
Name of extract claiming element
EXTRCN
element(5000)
As EXTCNN, but applied recursively to each connection
EXTRCO
element(5000)
As EXTCON, but applied recursively to each connection
EXTREF
element
References to exit level
EXWIDTH
real
Exit Width
EZDI
real
End load point in section
