Data Model
Introduction to Attributes
List of All Attributes
: Attribute D
Attribute D
Attribute Name
Data Type
Qualifier
Description
D
real
Position downing
DACC
string
Database access
DACCLA
logical
True if DAC allows element to be claimed
DACCOH
logical
True if DAC allows element hierarchy to be copied to another DB
DACCOP
logical
True if DAC allows element to be copied to another DB
DACCRE
logical
elemtype
True if DAC allows element to be created
DACDEL
logical
True if DAC allows element to be deleted
DACDRO
logical
True if DAC allows element to be dropped
DACERR
string(120)
attr
Returns the DAC error
DACEXH
logical
True if DAC allows element hierarchy to be exported
DACEXP
logical
True if DAC allows element to be exported
DACISS
logical
True if DAC allows element to be issued
DACMOD
logical
attr
True if DAC allows attribute of element to be modified
DACOUH
logical
True if DAC allows element hierarchy to be output
DACOUT
logical
True if DAC allows element to be output
DAREF
element
Reference of associated dataset area
DARREF
element
Design area reference
DASSCI
element(500)
Reference Array of all direct associates with constraints
DASSOS
element(500)
Reference Array of all associations with constraints
DATASO
element(10)
DBView or DBViewSet reference array for Datasheet Template
DATE
string(12)
Date
DATEFO
string
Date format
DATIM
string(19)
LMI Date/time
DATINT
integer(2)
Date
DATONE
integer
Date 1
DATTWO
integer
Date 2
DATTXT
string(22)
Date
DBAC
string
DB Access, MULTIWRITE or UPDATE
DBALL
element(8000)
List of DBs allocated to location
DBATTRIBUTE
word
Database attribute
DBCL
string
DB Claim
DBCNTL
logical
True if element is in a control DB
DBEXNO
integer
DB Extract Number
DBF
element
Database reference attribute
DBFI
string
DB filename
DBFN
integer
DB file number
DBLC
element(1000)
List of LOCs belonging to a DB
DBLNKP
logical
Linked Documents (DB) distribution flag
DBLS
element(1000)
List of DBs belonging to MDB
DBNA
string
DB name
DBNU
integer
DB Number
DBOT
real
Bottom diameter
DBPR
element(8000)
List of DBs Primary at location
DBRBEG
integer
DB range start
DBREF
element
DB reference
DBREND
integer
DB range end
DBSESS
integer
Last DB session
DBSHIE
element(5000)
Database hierarchy within a DBSET
DBSLEV
element(5000)
Databases at a level within a DBSET
DBSLIS
element(5000)
Databases within a DBSET
DBSSTP
element(8000)
DBs in a stamp
DBSTF
element
Database set reference attribute
DBTE
string
DB Text Encoding
DBTY
word
DB type (DESI, CATA etc)
DBUsers
element(10000)
Current Users in the system using this DB
DBUSRX
element(10000)
Current Users in the system using this DB or any extract descendants
DBVAR
logical
True if element is in a variant DB
DBVWSTREF
element(50)
Database View Set reference array
DBWRITE
logical
True if element is in a writable DB
DCLA
string
Database claim mode
DCLNCO
string(120)
Default Ceiling Code
DCLNHE
real
Default Ceiling Height
DCLNTY
string(120)
Default Ceiling Type
DCODE
string
Direction code
DCON
word
Design PPoint connection type
DCORRO
real
Derived corrosion
DCRFA
element(10)
Array of Design datasets for Design Code/Criteria
DCSTYF
element
Design change style reference
DCTILT
real
Default Ceiling Tile Thickness
DDDF
string(1000)
Default Design data value
DDEF
real(3)
Port distance flexibility defaults
DDEG
real
Dimension line angle
DDEGTX
string(80)
Radial dimension angle text
DDEP
integer
Database depth within hierarchy (World is 0)
DDESP
real(100)
Design parameters as distance
DDIR
dir
Design PPoint spherical direction
DDNM
element
Design element reference
DDNMX
real
DDNM X position
DDNMXY
real(2)
DDNM XY position
DDNMY
real
DDNM Y position
DDNX
string(120)
Design element as text
DDOORS
real
Default Door Sill
DDPR
string(1000)
Design data property value
DDRFA
element(10)
Array of default design datasets (for template)
DEALAL
logical
True if location locked due to deallocation of dbs
DEALDB
element(300)
Reference array for locations where DB id being deallocated
DECGAP
real
Decoration Gap
DECMOD
integer
Decoration Mode
DECOFF
real(2)
Decoration offset
DECP
integer
Decimal places
DECREP
real
Decoration Repeat
DECSIZ
real
Decoration Size
DEFA
real
Default
DEFATT
word(2000)
Default List of all attributes for element
DEFERD
element(10000)
Deferred DBs in MDB
DEFHOM
element
Default allocation home
DEFSLO
real
Default pipe slope
DEFSPK
element
Default Reference of SPEC for branch members
DELANG
real
Angle applied to repeat elements
DELDSG
word
Delivery Designation flag
DELP
pos
D-position in structure
DELPE
real
Easting of D-Position in STRUC
DELPN
real
Northing of D-position in STRUC
DELPU
real
Upping of D-position in STRUC
DELTAE
real
Easterly Offset applied to repeat elements
DELTAN
real
Northerly Offset applied to repeat elements
DELTAU
real
Vertical Offset applied to repeat elements
DEMIX
integer
Index of Demote Status Value
DENS
real
Spot value of density
DEPATT
word(2000)
Attributes that a rule or catalogue parameterised expression is dependent upon
DEPD
string(250)
word
Default value of local design property
DEPL
word(100)
List of local design properties
DEPR
string(250)
word
Local design property value
DEPREF
element(500)
List of elements connected to branch tail
DEPTH
real
Depth
DESC
string(120)
Description of the element
DESGEO
element(5000)
Design geometrical dependencies
DESLNK
element(20)
Connectivity Design Model Link
DESMOD
integer
Design Mode
DESP
real(100)
Design parameters
DESREF
element(10)
Design reference
DEST
string(26)
Destination
DESXCL
logical
Design Outfitting excluded Geometry
DETA
logical
Detail flag
DETR
element
Detailing text reference
DFBRADIUS
real
element
Default bend radius
DFFL
real(6)
Displacement force flexibility
DFHOME
element
element, elemtype
Get default home element
DFLA
string
Radial dimension type flag
DFLF
real(3)
Translational spring values
DFLRCO
string(120)
Default Floor Code
DFLRHE
real
Default Floor Height
DFLRTY
string(120)
Default Floor Type
DFLT
string(500)
Default value for the attribute
DFLTA
string(1000)
Defaults for Type 1 annotation - special attribute for use by ADP
DFLTB
string(1000)
Defaults for Type 2 annotation - special attribute for use by ADP
DFLTC
string(1000)
Defaults for Type 3 annotation - special attribute for use by ADP
DFLTD
string(1000)
Defaults for Type 4 annotation - special attribute for use by ADP
DFNM
string(120)
Document filename
DFON
integer
Dimension text font
DFONTN
string(80)
Dimension text font name
DFUN
element
Default unit
DHTEST
integer(500)
Test locator expression
DHTEXT
integer(500)
Default home identifier expression
DIAM
real
Diameter
DIAREF
element(50)
Diagram reference array for schematic elements
DIME
logical
DRAFT user defined symbol dimension flag
DIMPOS
pos
Derived 3D dimension position
DIMTXT
string(40)
Dimensions text
DINTER
string(257)
Default Interference class
DINTHK
real
Default insulation thickness
DIR
dir
Direction
DIREV
dir
Direction evaluation
DIRXP
integer(500)
Direction expression
DISP
real(3)
Translation displacements
DIST
real(2)
Distances
DISTAG
string(50)
Display tag
DISTFH
real
integer
Distance from head
DISTFN
real
Distance from next point
DISTFP
real
Distance from previous point
DISTM
real(2)
Distances to M1 and M2 curves
DKEY
word
Data Key
DLCOLO
integer
Dimension line colour
DLCONU
integer
Dimension line colour number
DLEV
integer
Drawing level
DLFG
string
Linear/Angular dimension line flag
DLIM
real(6)
Displacement limit
DLIST
word(2000)
List of all possible dist att types
DLPN
integer
Dimension line pen
DLSTREF
element
Dimension linestyle Reference
DLSTYL
integer
Dimension linestyle
DMFA
element(2)
ISODRAFT Reference Dimension attribute
DMFL
real(9)
Displacement moment flexibility
DMSP
real
Lower limit to spacing between parallel dimensions
DMSPTX
string(80)
Dimension spacing text
DMSTRF
element
Dimension style reference
DMTX
string(1000)
Dimension text
DMTY
word(2)
DNST
real
Density
DOCNUM
string(40)
Document Number
DOCREF
element
Document reference
DOCXRF
element(500)
Return reference from Design element to DOCITM element
DOFF
real
Dimension line offset
DOFIL
string(73)
Drawing Object filename
DOUPGR
logical
True if element is recommended to be upgraded in current db
DPBO
real
integer
Design point bore
DPCO
word
integer
Design point connection type
DPCOU
integer
Number of valid design points
DPDI
dir
integer
Design point direction
DPFN
string(1024)
ISODRAFT dynamic detail plotfile name
DPGR
real
integer
Design Point Gradient
DPGRID
integer
ISODRAFT dynamic detail grid reference attribute
DPKEY
word
Draft derived Pline identifier key
DPLS
integer(200)
List of valid design points
DPOS
pos
Dimension line/arc position
DPPS
pos
integer
Design point position
DPREMA
real
Design pres. max
DPREMI
real
Design pres. min
DPRO
string(1000)
Parameterised Property Expression (Default)
DPSF
element
Design PPointset reference
DPVI
integer(200)
List of visible design points
DRAD
string(1000)
Radial offset
DRAWNO
string(26)
Drawing number
DREVAY
element(50)
DRWG revisions array
DRFILE
string(73)
Drawing File name
DRFNUM
integer(11)
Drawing file numbers
DRFTYP
integer(11)
Drawing File Types
DRGP
integer
Drawing priority (used to determine how to draw SCTN)
DRMXTL
integer
Draft general max text length
DRNE
dir
Plane normal at end of SCTN/GENSEC
DRNS
dir
Plane normal at start of SCTN/GENSEC
DRPS
pos
Derived position for steelwork
DRRF
element
Old spooler drawing reference
DRSSRE
element
Draft Symbol set reference
DRTITL
string(120)
Drawing title
DRTMPR
element
Draft template reference
DRWGN
string(1000)
Drawing number
DSCO
string(120)
Design code
DSESS
string(120)
integer
Date of specified session
DSET
logical(3)
Displacement limits set flag - ignore values if FALSE
DSGNTN
string
Designation
DSIAST
element(500)
Datasheet Instance assigned tags reference array for Datasheet Instance
DSIFIL
string(2000)
Datasheet Instance filename
DSNO
integer
Datasheet number
DSSUBT
string(2000)
Datasheet sub title
DSTITL
string(2000)
Datasheet title
DSTNCE
real
Distance
DSTREF
element
Datasheet Template reference for Datasheet Instance
DSTY
string
Radial dimension style flag
DTAN
string
Dimension text angle flag
DTANSA
string
Dimension text angle flag style angular DTANSA
DTANSL
string
Dimension text angle flag style linear DTANSL
DTANSR
string
Dimension text angle flag style radiant DTANSR
DTCH
real
Dimension text character height
DTCHTX
string(80)
Dim text char height text
DTCOLO
integer
Dimension text colour
DTCONU
integer
Dimension text colour number
DTER
string
Dimension terminator code
DTERID
integer
Dimension terminator ID
DTERSA
integer
Dimension term. code style angular DTERSA
DTERSL
integer
Dimension term. code style linear DTERSL
DTERSR
integer
Dimension term. code style radiant DTERSR
DTFL
string
Dimension text radius flag
DTIT
string(32)
Data Title
DTLELE
element(5000)
Datal Elements list
DTLH
real
Dimension text letter height
DTLLIST
word(2000)
Datal Attributes List
DTLTST
integer(8192)
Datal Test attribute
DTMPMA
real
Design temp. max
DTMPMI
real
Design temp. min
DTOF
real(2)
Dimension text offset
DTOFTX
string(80)
Dimension text offset text
DTOP
real
Top diameter
DTPN
integer
Dimension text pen
DTRA
real
DTRATX
string(80)
Dimension text radius text
DTRE
element
Data set reference
DTUL
string
Dimension text underlining flag
DTWTCL
string
Date of weight/cog calculation
DTXR
string(120)
RTEXT of detailing text
DTXS
string(120)
STEXT of detailing text
DTXT
string(120)
TTEXT of detailing text
DUCTHE
real
Default duct height
DUCTSH
word
Default duct shape
DUCTWI
real
Default duct width
DUNI
word
Distance units
DUNION
integer
DRAFT element union detail flag
DUPLIC
element(10000)
integer
Duplicates of the current element with the same attribute values
DUTY
string(120)
Duty
DVFL
logical
ADP detail views flag
DVSCL
real(500)
ADP detail view allowable scale list
DVTH
real
ADP detail views threshold
DWALLT
real
Derive wall thickness
DWDIR
dir
Draft world direction for pline or ppoint
DWGF
string(73)
DWG filename (No suffix)
DWID
string(1000)
Width offset
DWINSI
real
Default Window Sill
DWPOS
pos
Draft world position for pline or ppoint
DX
string(1000)
Cartesian X offset
DXL
string(1000)
Incremental X length
DY
string(1000)
Cartesian Y offset
DYL
string(1000)
Incremental Y length
