Data Model
Introduction to Attributes
List of All Attributes
: Attribute B
Attribute B
Attribute Name
Data Type
Qualifier
Description
BACKRE
element(1000)
attr
List reftable back references
BAEXSS
real
Bending Excess Arrive
BAIN
string
Before/After indicator
BANG
real
Beta angle
BASETYPE
word
Base type for the user-defined element type
BBFF
element(500)
Array of bounding Boundary Formers
BCPY
element
Backward copy reference
BDIA
string(1000)
Bolt diameter
BDTUL
logical
Boolean dimension text underlining flag
BEAD
real
Default Bearing value
BEAF
real
Bearing attractor factor
BEAL
real(2)
Bearing limits (Min/Max)
BEAS
logical
Bearing set flag - ignore Bearing values if FALSE
BELRFA
element(500)
All components in the PipePiece
BELTYP
integer(500)
All component types in the PipeSpool
BENDCORNERS
logical
Bend corners - true if fillet should be applied to the corners of kickplate
BENDMACREFERENCE
element
Bending Machine reference
BENDMC
element
Bending Machine Reference
BENT
logical
Bent flag
BEVCOD
real(10)
Bevel codes for edges
BEVEL
real
Bevel
BEVFLA
real
Bevel code, flange
BEVLEN
real(2)
Lengths of bevel
BEVLFT
real
Bevel code on left side of seam
BEVLI
real(3)
Lengths of I-bevel
BEVLV
real
Length of vertical bevel
BEVLX
real(3)
Lengths of X-bevel
BEVLY
real(3)
Lengths of Y-bevel
BEVM
real(2)
Bevel codes along M1 and M2 curves
BEVRGT
real
Bevel code on right side of seam
BEVTXT
string
Bevel text
BEVWEB
real
Bevel code, web
BFCOLO
integer
Backface colour
BFCONU
integer
Backface colour number
BFLE
string(1000)
Out of plane flexibility factor for bends
BFPN
integer
Backface pen
BFRF
element
Reference to real Boundary Former
BFSTREF
element
Backface linestyle Reference
BFSTYL
integer
Backface linestyle
BITE
word(25)
Bolt items
BITL
real(25)
Bolt item lengths
BJOINT
string
Bolt joint
BKEY
string(4)
DRAFT user defined base symbol/skey name
BLCKLM
logical
True if block limit seam
BLEN
real(200)
Bolt length
BLEXSS
real
Bending Leave Excess
BLNK
logical
Auto-blanking flag
BLRF
element(10)
Bolt reference array
BLSLEN
real
Length of blasting contours
BLTM
string(3)
Bolt method
BLTR
element
Bolt reference
BLTW
real
Standard Bolt weight
BMAR
real
Auto-blanking margin
BMAX
integer
Maximum bend number in current spool drawing
BMCLOC
logical
True if bending machine bends clockwise
BMLEVE
real(100)
Beam levels from owning element
BNDARE
real
Boundary line area
BNDOFF
real
Offset from boundary
BOLTPARTNUMBERS
integer(20)
Spooling bolt part numbers
BORE
real
Bore
BOREAR
real(10)
Bore array
BOTCUT
real
Bottom Stile Cut Distance
BPANNR
dir
Curved base panel normal
BPANOR
ori
Curved base panel orientation
BPANRE
element
Base panel reference
BPOF
real(4)
Leader bend point offset
BPOFTX
string(80)
Leader bend point offset text
BPRO
real
Spot value of property B
BRACKE
string
Brackets code
BRAD
real
Bend radius
BRALNK
element(20)
Connectivity SCBRAN-BRANCH Link
BRCOG
pos
Branch centre of gravity
BRCONNECT
element(5000)
Branch member connections
BREARE
real
Branch external surface area
BREF
element
Branch Reference
BRIARE
real
Branch internal surface area
BRICOG
pos
Branch insulated centre of gravity
BRIWEI
real
Branch insulated weight
BRLEG
element(5000)
Branch members on the same leg
BRLO
integer
Branch Positioning Status code (Router)
BRNFAC
real
Burning factor
BRNGSP
real
Bottom Rung Spacing
BRNLEN
real
Length of burning contours
BRNNAM
string(26)
Burner name
BRNNUM
integer
Burner number
BRNPRC
string(26)
Burner process name
BRNREF
string(26)
Burner reference id
BRNSEQ
string(26)
Burning sequence number
BRNST
integer
Number of starts for burning
BRNTOO
integer
Burner tool
BRNTYP
string(26)
Burner type
BRREF
element
Branch table reference
BRTXRF
element(500)
Return reference from Branch Table element to SPECs
BRWCOG
pos
Branch wet centre of gravity
BRWEIG
real
Branch weight
BRWICOG
pos
Branch wet insulated centre of gravity
BRWIWEI
real
Branch insulated wet weight
BRWWEI
real
Branch wet weight
BSCANG
real
Bend Segment Cut Angle
BSCLL
real
Centre-Line Length of a mitred Bend Segment
BSDWG
string(120)
AutoCAD backing sheet name
BSEL
string(3)
Bolt Selector
BSFN
string(1024)
Backing sheet filename
BSLAYE
string(120)
AutoCAD backing sheet layer
BSMNIL
real
Minimum Length of Insulation of a mitred Bend Segment
BSMNL
real
Minimum Length of a mitred Bend Segment
BSMXIL
real
Maximum Length of Insulation of a mitred Bend Segment
BSMXL
real
Maximum Length of a mitred Bend Segment
BSPE
element
Bolt specification
BSRF
element
Backing sheet reference
BSRFA
element(500)
ADP backing sheet list
BSTA
integer
Branch Status code (Router)
BTEX
string(1000)
Annotation text string
BTHK
string(1000)
Parameterised bolt thickness
BTLS
word(50)
Boundary Former type list
BTOL
string(1000)
Bore tolerance
BTOTAL
integer
Bolt joint total
BTOTWE
real
Bolt total weight
BTYP
string(1000)
Bolt type
BUFS
integer
Preferred buffer size
BUIL
logical
Built/Unbuilt flag
BULG
real
Bulge factor
BUNI
word
Bore units
BUNREF
element
Cable bundle reference
BURF
element
Reference to real Building Element
BURNID
string(80)
Burner id
BVCODN
integer
Bevelled Code number
BVIS
logical
Bottom visibility flag
BVSCLL
real
BVSEGN
integer
Bevelled segment number
BVSMNI
real
Minimum Length of Insulation of a Virtual mitred Bend end-Segment
BVSMNL
real
Minimum Length of a virtual mitred Bend end-Segment
BVSMXI
real
Maximum Length of Insulation of a Virtual mitred Bend end-Segment
BVSMXL
real
Maximum Length of a virtual mitred Bend end-Segment
BWEI
real(200)
Bolt weight
BWITHF
logical
Bend with flow
