Data Model
Pseudo Attributes
: Attribute Category: Structural
Attribute Name
Data Type
Qualifier
Description
AANGXZ
real
Angle of attached SCTN in XZ plane of joint
AANGYZ
real
Angle of attached SCTN in YZ plane of joint
ACTL
real
Actual length
ANPJ
pos
Attached neutral point of joint (steelwork)
ANPS
pos
Attached neutral point of section (steelwork)
BPANOR
ori
Curved base panel orientation
BPANRE
element
Base panel reference
CUTL
real
Cut length
DELPE
real
Easting of D-Position in STRUC
DELPN
real
Northing of D-position in STRUC
DELPU
real
Upping of D-position in STRUC
DISTFH
real
Distance from head
DISTFN
real
Distance from next point
DISTFP
real
Distance from previous point
DRNE
dir
Plane normal at end of SCTN/GENSEC
DRNS
dir
Plane normal at start of SCTN/GENSEC
ECCE
pos
Eccentricity (steelwork)
ECCJ
pos
Eccentricity of joint (steelwork)
HIERARCHY
element(5000)
Structural connections
HRJUSL
word
Handrail Justification Line
JUSL
word
Justification Pline
LENG
real
Length
LENSEG
real
Length of segment
LINKS
element(5000)
Linked elements
LOHE
real
PLOOP height - from first PLOOP in owning panel
MIDP
pos
Section midpoint (steelwork)
ONPJ
pos
Owning neutral point of joint (steelwork)
ONPS
pos
Owning neutral point of section (steelwork)
PALIG
real
Panel alignment
POSE
pos
End point position
POSEE
real
Easting of end point position
POSEU
real
Upping of end point position
POSEY
real
Northing (Y coordinate) of end point position
POSS
pos
Start point position
POSSE
real
Easting of start point position
POSSN
real
Northing of start point position
POSSU
real
Upping of start point position
PSIZE
real(2)
Panel size
RATTAL
element(500)
word
Ratta list
SLRAP
element(500)
Sorted list of RATTA after POINTR
SLRBP
element(500)
Sorted list of RATTA before POINTR
TCTL
real
True cut length
UBULG
real
Used bulge factor for curve geometry
UCURTYP
word
Used curve type
URADI
real
Used radius for curve geometry
YDIR
dir
Preferred Y axis direction
ZDIR
dir
Additional axis direction
