Data Model
Pseudo Attributes
: Attribute Category: SPOOL
Attribute Name
Data Type
Qualifier
Description
AWDOWN
integer(3)
Table linking AWELD elements to piping components
AWDREF
element(20)
Return reference to AWELD element
AWELDS
integer(20)
Weld numbers of attached welds
BOLTPARTNUMBERS
integer(20)
Spooling bolt part numbers
ITMTBL
integer(2000)
Table linking AITEMS elements to piping components
IWDORF
element(1500)
Weld owners attribute on IWELD elements
IWDOWN
integer(8)
Table linking IWELD elements to piping components
JNTORF
element(1500)
Joint owners attribute on IJOINT elements
JNTOWN
integer(8)
Table linking IJOINT elements to piping components
JNTREF
element
integer
Return reference from Ppoint to ijoint element
MTOPARTNUMBERS
integer(20)
Additional spooling item part numbers
PARTNUMBER
integer
Part number of a spooled component or leave tube
PBENDNUMBER
integer
Spooling pulled bend number
RWDOWN
integer(2)
Table linking RWELD elements to design WELD elements
RWDOWN
element
Reference of associated WELD of RWELD element
SFREF
element
Return reference from piping component or leave tube to spool or field element
SPLMEM
element(1500)
Spooling table attribute on SPOOL or FIELD elements
SPLPARENT
element(500)
elemtype
Branches referenced by a SPLDRG, SPOOL or FIELD
SPLTBL
integer(2000)
Table linking SPOOL & FIELD elements to piping components
SPLVOLUME
real(3)
Volume of a SPOOL element
SPOONUMBER
string(120)
Spool number including spool prefix
WBORE
real
Bore on IWELD/RWELD
WJPOS
pos
Implied weld position
WLDREF
element
integer
Return reference from Ppoint or WELD to IWELD or RWELD element
WSHOP
logical
Weld shop/site flag on IWELD/RWELD
WSPEC
element
Weld specification on IWELD/RWELD
