Data Model
Pseudo Attributes
: Attribute Category: Hull
Attribute Name
Data Type
Qualifier
Description
APARMS
real(9)
All parameters
ASREF
element
Assembly reference
ATWLEN
real
Assembly total weld length
BENT
logical
Bent flag
BEVEL
real
Bevel
BEVFLA
real
Bevel code, flange
BEVLFT
real
Bevel code on left side of seam
BEVM
real(2)
Bevel codes along M1 and M2 curves
BEVRGT
real
Bevel code on right side of seam
BEVTXT
string
Bevel text
BEVWEB
real
Bevel code, web
BLCKLM
logical
True if block limit seam
CLIPCD
integer
Clip code
CLOSED
logical
True if plate covering entire referenced component
CMALL
real
Structure allowance
CMBOUA
element
Aft boundary
CMBOUF
element
Fwd boundary
CMBOUL
element
Lower boundary
CMBOUP
element
Ps boundary
CMBOUS
element
Stbd boundary
CMBOUU
element
Upper boundary
CMBOX
real(6)
Bounding box
CMCAT
string(256)
Compartment category
CMCDE
real
Content density
CMCTID
string(256)
Content type ID
CMDESC
string(256)
Compartment description
CMFLW
real
Full Load Weight
CMLCV
real
Longitudinal centre of total volume
CMMGE
integer
Merged compartment indicator
CMPER
real
Compartment permeability
CMPERD
real
Permeability for use in damage
CMPURP
string(256)
Purpose
CMTCV
real
Transverse centre of total volume
CMTYP
integer
Type of compartment
CMVCV
real
Vertical centre of total volume
CMVOL
real
Total volume
CNTNUM
integer
Contour number
COMNT
string
Comment
CONAM
string
Cutout name
CONCD
integer
Connection code
CONDES
string
Connection string
CONTYP
string
Connection type
CORNUM
integer
Corner number
DATINT
integer(2)
Date
DEST
string(26)
Destination
DIST
real(2)
Distances
DISTM
real(2)
Distances to M1 and M2 curves
DSGNTN
string
Designation
DSTNCE
real
Distance
DTWTCL
string
Date of weight/cog calculation
EDPUV
pos
End point
EPARAM
real(6)
Evaluated parameters
EXCESS
real
Excess
EXCLFT
real
Excess on left side of seam
EXCRGT
real
Excess on right side of seam
EXCTLF
integer
Excess type on left side of seam
EXCTRG
integer
Excess type on right side of seam
EXTNSN
real
Extension
FLATYP
integer
Flange type
FNCCD
integer
Functional description code
FNCTXT
string(80)
FOLDED
logical
True if folded
GENSTR
string
General strings
GPSTR
string
General purpose strings
GRIND
real
Grinding info
HGHT
real
Height
HLCOLO
string
Hull Colour
HULCNT
integer
Size of hull array/collection
HULLOB
element
Hull object reference
HULOC
string
Location
HUMVW
string
Model View
HUREFL
logical
Reflected
HUREPL
element
Replica
HUSYMM
logical
Symmetrical
IDENT
string
Panel identification string
INCL
real
Inclination angle
INSTNC
string
Bracket instance name
ISECPT
pos
Intersection point
KNUANG
real
Knuckle angle
KNUCKL
logical
True if knuckled
LIMNUM
integer
Order number of limit
MACRID
string
Clip macro ID
MANBLK
string
Name of owner block
MANPAN
string
Name of owner panel
MANTRA
real(16)
Transformation from local coordinate system
MIRROR
logical
True if mirrored in local v-axis
MODREF
element
Model reference
MOULEN
real
Mould length
NOMARK
logical
True if unmarked
NOPGS
integer
Number of openings
NTRLEN
real
Neutral length
OBJCD
integer(2)
Object codes
OFFSET
real
Offset
OGDSTS
real(25)
Distances to openings
OUTFRF
element
Reference of matching outfit object
OVRSH
real
Overshoot (d-measure) for unsymmetrical flange
PANREF
element
Panel reference
PANSID
integer
Side of panel
PARAL
logical
True if tap parallel to referred seam
PARM
real(6)
Parameters
PARNAM
string(256)
Part name
PARREF
element(10)
Part reference
PLAREA
real
Area
PNTUV
pos
Point2D
PNTXYZ
pos
Point3D
POINUM
integer
Point Num
POSNO
integer
Position number
PRTIDL
string(132)
Long part id
PRTIDM
string(132)
Module part id
PRTIDS
string(132)
Short part id
PRTLST
string(26)
Parts list name
QUACD
integer
Quality code
QUATXT
string(26)
Quality
RAWPLA
element
Raw Plate
REFLCL
logical
True if reflected in CL
RSBOX
real(6)
Bounding box of RSO
RSFFD
integer
Functional description on face
RSFMC
integer
Material code on face
RSFMS
string(256)
Material side on face
RSFMT
real
Material thickness on face
RSFSA
logical
Auto stiffening on face
RSFSD
string(256)
Profile dim on face
RSFSS
string(256)
Stiffener side on face
RSFST
integer
Profile type on face
RSFWT
logical
Watertight
RSLBRA
string(256)
Bracket instance at limit
RSLELE
element
Limiting element
RSLPRE
integer
Profile end definition at limit
RSPAN
element(1000)
Panel(s) defined on RSO
RSPLN
integer
Principal plane of RSO
RSTYP
integer
Type of RSO
SCHEME
string
Scheme name
SDTINT
integer(2)
Splitting date
SDTTXT
string(22)
Splitting date
SHFALG
real
Shrinkage factor along main direction
SHFPRP
real
Shrinkage factor perpendicular to main direction
SHFSEA
real
Shrinkage factor for seams perp. to main direction
SHPUV
pos
Point defining shrinkage
SHVUV
dir
Vector defining shrinkage
SPECIF
logical
True if outer panel contour on PS/SB are different
SPLA
string
Name of spigot plate
SPPOSN
integer
Position number of spigot plate
STPUV
pos
Start point
STREAT
string(26)
Surface treatment
STRXPL
logical
True if surface treatment explicitly defined
SYMLNS
integer
Side of direction vector
SYMM
integer
Symmetry code
SYMXYZ
dir
Vector along symmetry line
TAGCD
integer
Tag code
TAGCDS
integer(25)
Tag codes
TAGNMS
integer(25)
Tag numbers
TAGNUM
integer
Tag number
TOTLEN
real
Total length
TPLFRR
element(10000)
Topology references
TWIST
logical
True if twisted
TWSTAN
real
Twist angle
TYPECD
integer
Type code
TYPECE
integer
Type code
WELDDP
real
Welding depth
