Data Model
Pseudo Attributes
: Attribute Category: Catalog Values for Piping Item
Attribute Name
Data Type
Qualifier
Description
AALLAN
real
Arrive Ppoint allowed angle
ABOP
pos
Bottom of arrive pipe
ABOR
real
Arrive bore
ACON
word
Arrive connection type
ACORRO
real
Arrive corrosion allowance
ADIR
dir
Arrive direction
AGRD
real
Arrive Ppoint gradient
AOD
real
Arrive Ppoint outside diameter
APOS
pos
Arrive position
APOSE
real
Easting of arrive position
APOSN
real
Northing of arrive position
APOSU
real
Upping of arrive position
AQAANG
real
Angle between alignment direction of arrive pp and previous
AQANG
real
Angle between arrive Ppoint and previous component
AQBORE
logical
TRUE if arrive Ppoint has same bore as previous
AQCON
logical
TRUE if arrive Ppoint has Correct connection type
AQOFF
real
Offset between arrive Ppoint and previous component
ATCORR
real
Arrive tube corrosion allowance
ATOP
pos
Top of arrive pipe
ATWALL
real
Arrive tube wall thickness
AWALLT
real
Arrive wall thickness
AZDIR
dir
Arrive alignment direction
BJOINT
string
Bolt joint
BTOTAL
integer
Bolt joint total
DCORRO
real
Derived corrosion
DFBRADIUS
real
element
Default bend radius
DWALLT
real
Derive wall thickness
FLALLO
real
Flange allowance
FLOFFS
real
Flange offset
HCORRO
real
Head Corrosion
HWALLT
real
Head wall thickness
LALLAN
real
Leave Ppoint allowed angle
LBOP
pos
Bottom of leave pipe
LBOR
real
Leave bore
LCON
word
Leave connection type
LCORRO
real
Leave corrosion allowance
LDI
dir
Leave direction
LGRD
real
Leave Ppoint gradient
LOD
real
Leave Ppoint outside diameter
LPOS
pos
Leave position
LPOSE
real
Easting of leave position
LPOSN
real
Northing of leave position
LPOSU
real
Upping of leave position
LQAANG
real
Angle between alignment direction of leave Ppoint and next
LQANG
real
Angle between leave Ppoint and next component
LQBORE
logical
TRUE if leave Ppoint has same bore as next
LQCON
logical
TRUE if leave Ppoint has Correct connection type
LQOFF
real
Offset between leave Ppoint and next component
LTCORR
real
Leave tube corrosion allowance
LTOP
pos
Top of leave pipe
LTWALL
real
Leave tube wall thickness
LWALLT
real
Leave wall thickness
LZDIR
dir
Leave alignment direction
MAXB
real
Maximum bore
NOMBIN
real(200)
word
List of valid Nominal bores in Inches
NOMBMM
real(200)
word
List of valid Nominal bores in MM
PALLAN
real
integer
PBOP
pos
integer
Bottom of pipe
PCORRO
real
integer
P Tube corrosion
PCWALL
real
integer
Ppoint connect wall thickness
PFLALL
string(1000)
Flange allowance parameter
PFLOFF
string(1000)
Flange offset parameter
PHBO
real
Pipe head bore
PHBP
pos
Bottom of pipe head
PHCO
word
Pipe head connection type
PHDR
dir
Pipe head direction
PHGR
real
Pipe head gradient
PHOD
real
Pipe head outside diameter
PHPO
pos
Pipe head position
PHTP
pos
Top of pipe head
PQAANG
real
integer
Angle between alignment direction of specified pp and adjacent component
PQANG
real
integer
Angle between specified Ppoint and adjacent component
PQBORE
logical
integer
TRUE if specified Ppoint has same bore as adjacent
PQCON
logical
integer
PQOFF
real
integer
Offset between specified Ppoint and adjacent component
PTBO
real
Pipe tail bore
PTBP
pos
Bottom of pipe tail
PTCO
word
Pipe tail connection type
PTDR
dir
Pipe tail direction
PTGR
real
Pipe tail gradient
PTOD
real
Pipe tail outside diameter
PTOP
pos
integer
Top of pipe
PTPO
pos
Pipe tail position
PTTP
pos
Top of pipe tail
PWALLT
real
integer
Ppoint wall thickness
RANANG
real(32)
elemtype
Range of available angles for bends and elbows
RANRAD
real(32)
elemtype
Range of available radii
TCORRO
real
Tail Corrosion
TWALLT
real
Tail wall thickness
WALLTH
real
Tube wall thickness
WTHICK
real
Wall thickness
