Data Model
Pseudo Attributes
: Attribute Category: Catalog
Attribute Name
Data Type
Qualifier
Description
BRTXRF
element(500)
Return reference from Branch Table element to SPECs
BTHK
string(1000)
Parameterised bolt thickness
BTYP
string(1000)
Bolt type
CCORXR
element(500)
Return reference from CCORSET element to SCOMs
COCDRE
element(500)
word
COCDESS with same COCONN value as qualifier
COCOXR
element(500)
COCO description return reference
COCSAM
element(500)
COCOS with same CTYP value as COCDES
CTYPLI
word(500)
List of COCO Ctypes
DESGEO
element(5000)
Design geometrical dependencies
DUPLIC
element(10000)
integer
Duplicates of the current element with the same attribute values
GEODEP
element(5000)
Direct geometrical dependencies
HDUPLI
element(10000)
integer
Duplicates of the current element (checking members)
LBBORE
logical
TRUE if Minor/Branch bore is in nominal bore table
LHBORE
logical
TRUE if Major/Header bore is in nominal bore table
LRBORE
logical
TRUE if bores is in reducer table
LTBORE
logical
TRUE if bores is in branch (tee) table
NOMXRF
element(500)
Return reference from NOMTAB element to SPECs
PRTRTX
string(1000)
word
Part element R text
PRTSTX
string(1000)
word
Part element S text
PRTTTX
string(1000)
word
Part element T text
PRTXRF
element(500)
Return reference from PART element to SPCOs
REDXRF
element(500)
Return reference from Reducer Table element to SPECs
