Data Model
Pseudo Attributes
: Attribute Category: Cabling
Attribute Name
Data Type
Qualifier
Description
ACLIST
element(500)
Arriving cables to attached point
ATCONN
element(500)
List of elements connected to attachment
AYDIR
dir
Arrive Y axis direction
CABBOX
real(6)
Calculated box volume in world coordinates
CBACXR
real
Accumulated cables xarea at route node
CBCOG
pos
Cable centre of gravity
CBCULE
real
Cut Length of cable
CBGELE
real
Geometric Length of cable
CBNUCW
element(500)
Cables at a point on a cableway
CBPREF
element(500)
References to POINTR forming route of a cable
CBRNLS
element(500)
List of route nodes that cable passes
CBRWGL
real
Raw Geometric Length of cable
CBTOLE
real
Total Length of Cable
CBWEIG
real
Cable weight
CFILL
real
Fill level at route node
CFRELE
real
Free Length of cable
CLIST
element(500)
All cables attached to route node
CMAXF
real
Calculate maximum fill level on cway
CMINF
real
Calculate minimum fill level on cway
CONATS
element(500)
List of attachment connected to attachment
CONBRA
element(500)
List of branches connected to branch
CONNE
logical
Segment end connection flag
CONNS
logical
Segment start connection flag
CONSIS
logical
Position consistency
CWJUSL
word
Cable Way Justification Line
CWLIST
element(500)
All cableways attached to route node
DEPREF
element(500)
List of elements connected to branch tail
ELCXRF
element(500)
Return reference from CABLE element to ELCONN element
FCENTRE
pos
Centre of fillet arc
FEND
pos
Fillet arc position
Fill level check
logical
Fill level check
FILREF
element(500)
Sorted references to attachment points with ascending order of fill level greater then 0
FLEVEL
real
FMID
pos
Middle point of fillet arc
FSTART
pos
Fillet start position
HDCONN
element(500)
List of elements connected to branch head
HDREF
element(500)
LALCAB
element(500)
List arriving leaving cables on attached point
LYDIR
dir
Leave Y axis direction on point
MINFIL
real
Min Fill level on Cableway and Cabletray components
NPLIST
element(500)
All NATPs attached to route node
NUMCOR
integer
Number of cores in a cable
POITYP
string(120)
Point type
PRFELE
element
Cableway profile element
PRFOBS
integer
Cableway profile obstructions
RATTAL
element(500)
word
Rnode list
TLCONN
element(500)
TLREF
element(500)
TXAREA
real
Total Cableway X-area
VRADI
real
Cableway radius
