Common Functionality
Model Editor
Graphical Component Modification (GCM)
: Selection Set for GCM
The movement handle is only shown when the selection set contains:
A single Piping Component which does not cause the Branch to change direction, i.e. the Component has a parallel Arrive and Leave direction:
A sequential set of Piping Components which lie within the same leg of a Branch, i.e. there is no change in direction or a bad alignment exists in the leg:
In the following example the Component Modification Handle is
not
displayed.
In this example the Component Modification Handle
is
displayed
The Component Modification Handle only appears where the selected Component(s) conform to the rules as defined above.
By default the origin of the initial Component identified to define a selection is used to position the handle.
Picking a Component already within the selection set moves the handle to the origin of the identified element:
However, selecting an item in the selection with the primary mouse button does
not
change the position of the handle; it only shows the appropriate selection for the identified item.
