Global : Transfer : Transfer Using Command Syntax
The user can access the Transfer functionality from the Command Window. The user can type the Syntax in the Command Line, for use in PML macros and functions. The CONNECTIONS option is currently only available through the command-line.
EXTRACT TRANSFERNOW <element-list> 'session-comment'
EXTRACT TRANSFERNOW <element-list> HIERARCHY 'session-comment'
EXTRACT TRANSFERNOW CONNECTIONS <element-list> 'session-comment'
