Reporting : Simple Reports
The Simple Reports option allows the user to create reports with basic formatting. On the Tools tab, in the Report group, click Simple Report to display the Simple Report window.
The Simple Report window allows the user to quickly generate reports, however the report template cannot be saved.
Select Screen check box to ignore any filename specified and only output to screen.
If the Type text box is left blank ALL TYPES is reported on.
The With option is a way of narrowing down the report. Type an expression, for example:
Click Run to generate the report. Click Cancel to close the window.
