On the Home tab, in the
Common group, click
Attributes, select
General from the drop-down list to display the
Query window. The options on the general query menu allows the user to query current data settings.
The Specific drop-down menu is only applicable when the current element has attributes which are specific to that element type. For example, if the current element is a Nozzle, the options under
Specific is Bore, Direction and Connection. Select the attribute for which the user wants to output the value.
