Data Check : Mass Properties
User Input - Usually for Weight and CofG of elements such as equipment and vessels.
Catalogue Data - Usually for Weight of components such as Pipe fittings, tables and chairs.
3D Model Calculation by the System - Weight can be calculated for such as Beams, Columns, Panels where the Volume is used in combination with the material density. Volume and Surface area are always calculated by the System.
Weight and CofG do not currently support inside/outside qualifiers.
