Data Check : Systems : Navigate the Modify Design System
The Modify Design System window is divided into sections, to the top left Database Items displays the members of the currently selected element that can be added to a system (elements with an MDSYSF attribute). The Primary System attribute value is also displayed.
The Main Systems and Owning Systems tabs displays the current system information for the element selected in the Database Items part of the window. Both tabs appear blank until a system is assigned to an item.
To the top right the System Explorer displays the available systems in the database hierarchy.
Click on a SYSGRP element in the System Explorer to display it's members in the System Members pane. The list of System Members appear blank until a member is assigned.
