Modify : Properties
The Properties window allows the user to edit component properties such as weights and material data if the item has properties that can be modified.
On the Home tab, in the Common group, click Modify Properties to display the Properties window.
Click Apply to confirm the property change.
Click Default to load the default values.
Click Reset to reload the current values.
Click Cancel to close the window.
