Settings : Purposes : Relationships
To define the required purposes, on the Admin tab, in the Purposes group, click Relationship to display the Purpose Relationship window.
Click File > Save to save the file to the current filename.
Click File > Save As to display a File Browser window to save the file with a new name.
Click File > Load to reload the file from the current filename.
Click File > Load From to display a File Browser window to load a different file.
Select the Type from the drop-down menu, Then the drop-down menu to the right displays the list of purposes defined for the chosen type.
Select the Sub Type from the drop-down menu.
Select Set to Purpose check box.
Click Cancel to close the Purpose Relationship window.
