Use the Position By window to move an element to a specified distance in a specified direction, relative to its current position.
The user must first select the element to be moved in the Model Explorer or 3D graphical view. On the
Home tab, in the
Common group, click
Position Relatively By, select
Position from the drop-down list to display the
Position By window.
Input the distance and direction in the co-ordinate text fields and if required, in the wrt text field, input the name of the element to which all co-ordinates are interpreted with respect to.
If required, select one or all of the Lock check boxes to fix the current co-ordinate along the
E,
N or
U axis.
Alternatively in the 3D graphical view, the user is prompted to Measure distance start (Snap) Snap: click to identify the start point (this must be an element), the Measure Start Distance is displayed in the 3D graphical view.
The user is now prompted to Measure stop distance (Snap) Snap: Click to identify the stop point (this must be an element), the new position is calculated and displayed in the
Position By window or in the 3D graphical view.
Click Apply, the selected item is moved to its new position. To position by another item, click to select from the
Element drop-down list:
