Hole Management System : Addition of Managed Holes : Project Configuration for Hole Management
If these criteria for Fixing elements are not met, the hole management system does not function.
If these criteria for Coaming elements are not met, the hole management system still functions but the coaming option is greyed out.
The extrusion to be used as the penetration profile is first created in the equipment or design template, and is then identified using the Identify Penetration Shape window. The window creates two elements owned by the equipment or design template element. The first is a Port Set (PORS) element that must have its Purpose attribute set to HOLE, which owns a port (PORI) element which has a reference to the penetration profile extrusion.
