Hole Management System : Addition of Managed Holes : Modify Penetration
In each of the applications that have a Penetrations menu, there is a menu command that displays the Hole Management - Definition window if the status of the penetration allows the user to modify the selected penetration, for example on the Piping tab, in the Penetrate group, click Holes, select Modify Hole from the drop-down list.
The Add option allows new penetrating items to be added to an existing penetration.
Click Add to display the Add Penetration window:
When the user clicks Pick Penetrated Items, the user is prompted to identify one or more penetrating items to add to the Managed Hole currently being modified.
Click OK to calculate the position of the penetration for each new item and returns to the Hole Management Definition window where the new penetrating items are added to the existing managed hole. If the Managed Hole being modified is a single penetration, it is converted to a merged penetration. The Hole Management Definition window is then used to modify the definition of the managed hole to include the requirements of the new penetrating items.
To modify a room application door or window managed hole, right-click on the association on the Hole Association Manager window and select Modify Definition from the right-click menu.
