Hole Management System : Addition of Managed Holes : Merged Hole Penetrations
The Hole Management Definition window has a Merged Penetrations option that requests a single hole that contains all penetrating items. When this is selected, a new hole class called User Defined Profile appears in the Hole Shape Selection Class drop-down list. When this is selected, a hole shape that contains all penetrating items is calculated by the system by merging the individual requirements of the penetrating items.
Click Edit profile shape link allows the hole shape to modified by using the standard loop vertex editor.
Changing the hole clearance or reselecting the User Defined Profile option replaces the modified hole shape with a new shape calculated by the system. Positioning functions are disabled for User Defined Profiles.
