DRAW Administrator Guide
Sheet Library : Create Backing Sheet
To create a Backing Sheet, on the Project tab, select New to display the New screen.
To display a list of available Templates, click Backing Sheet. The Template Types can be changed by selecting an option from the drop-down list. After selecting the options, click Create to display the Create Backing Sheet window.
The Create Backing Sheet window has similar functionality to the Hierarchy Browser. The Hierarchy Browser is explained. Refer to Hierarchy Browser for further information.
Input a name in the Name field, or leave it blank if the element is to be assigned a name automatically.
To create the new element, click Create. A new sheet is then created and opened. The administrator can now modify the new sheet, for example, create the borders, using the standard drawing and annotation facilities.
Click Cancel to discard any changes and close the Create Backing Sheet window.
