DRAW Administrator Guide
Sheet Library : Modify Sheet Library
To modify a sheet library, select the sheet library in the hierarchy to make it the CE. On the Admin tab, in the Libraries group, click Sheet, select Modify from the drop-down list to display the Sheet Library window. The administrator can make the required changes and click Apply. Refer to Create Sheet Library for further information.
