DRAW Administrator Guide
Area Based Automatic Drawing Production
Limitations
: Rule Expressions
Rule Expressions
In setting classification and Tag Rules, the administrator is using expressions to extract 3D model elements.
It is perfectly legitimate to use the syntax:
ALL WITH (PURP EQ ‘ABC’)
However, although it produces the required result, it is time consuming since all the databases in the whole MDB are scanned if opened in read mode.
It is better to include a qualifier in the command:
ALL EQUI WITH (PURP EQ ‘ABC’)
