DRAW Administrator Guide
Area Based Automatic Drawing Production
User Tasks
: APSKEYPLAN
APSKEYPLAN
A keyplan view task, that is supplied as TASK /Aba/view_task5 with a matching PML function samkeyplan.pmlfnc.
The task is designed to create a hatched 2D element under the keyplan view which represents the area limits of that view.
A keyplan view is defined as a VIEW element with attribute sppurp set to ABAK which is set using the View Function keyplan option on the ABA Template View window. Refer to
Create and Modify Labelling
for further information.
The drawlist contents of this view are set to the keyplan discipline.
The hatched area is an OUTL element created under a VNOT element with vertices at each corner of the area limits.
The VNOT is created in a unique LAYE element which is named per the view plus a suffix /KeyplanHatch.
